If i install a GT35 turbo what is the correct/safe size injectors i should buy..a lot of people are telling me to go big. will the sti pinks fair well?
Injectors are not the only thing going to have be changed for a 35r. Your going to need all the basics as well such as em, fuel pump and more. Are you going to buy a kit or just the turbo and piece the kit together? Personally I would rethink that turbo size on an 03 because its only a 2 litre. If you want to go that big you might want to go with just a 30r. Anyways good luck!
So 30r will be good but still go 1000cc injectors? Looking for a bolt on 30r because i already have all other parts installed already..all i need is turbo, injectors, and fuel rail...then a tune
the best way to figure out exactly what you need is to find a tuner you want to tune your car and talk to them about your setup. They will point you in the direction you need to be in. And what are all of the other parts you have already for your 30r setup? Sounds like you're not quite sure what you want. You wanted a 35r a day ago now you want a 30r. What are you're goals with the car?
Look into the blouch dom series, atp kits or even an fp red or fp green. Most of those are stock mount turbos and give you a ton of power. I am looking for around this size turbo for my sti. I just cant decide if I want to go rotated or not.
if your're going rotated do the atp! There are some really good review threads on these turbos on nasioc. They make some impressive power for a stock location. I really like mine.
I don't know what your goals are but you likely won't be able to get there due to your EJ205 and stock 5-speed. If you change those out, you'll have a prayer of running a turbo that size effectively.
Exactly why I upgraded to Sti I just couldnt push bugeye anymore without spending a small fortune. Sti is way better platform to play with you got to love it.
dont wanna change the thread theme but when i refuel my car, it doesnt want to turn on/start... i have to step on the gas then it turns on...it only happens when i refuel though...i did some research im set on a 18g turbo... 100% sure this time... hope it goes well
OT, but yes it is suddenthomas. Suby777, you'll need bigger than STI pinks for the 18g also.
