GrimmSpeed Project L - Page 4 - Subaru WRX Forum
post #46 of 194 Old 09-20-2007, 09:59 AM Thread Starter
GrimmSpeed is an unknown
Send a message via AIM to GrimmSpeed
H6 updgrade as been started. this is really a simple mod. the only things you need are an H6 sized rotor, H6 caliper bracket, impreza LX or WRX rear caliper. there is defiintely a big difference in rotor size bettwen the weak LX rotor and the leggy H6. i think next time i need to replace the rears i'm going to get the old turbo leggy rear vented rotors.
GrimmSpeed
GrimmSpeed is offline
post #47 of 194 Old 09-20-2007, 11:41 AM
atxwrx's Avatar
Images: 13
atxwrx is an unknown
I know that this has been said, but I can't wait to see the finished product. Keep on doin what you are doin.
atxwrx is offline
post #48 of 194 Old 09-21-2007, 12:17 AM Thread Starter
we got the new prototype rear camber plates in today from BC Racing. These arent on the market yet so we are trying them out for BC. install was pretty simple with just the supplied tools(preload adjusting wrenches, 6mm allen), 14mm wrench, and a 17mm wrench. everything bolted up perfectly except i had to move the outside allen head bolts to the inside because they were hitting on the fender hole.
first you will want to mark your current preload position for the spring. we used some fashionable pink finger nail polish to mark the spot.
these are the wrenches that are included with the coilovers to adjust the spring preload. loosen the lower one first, then proceed with the second. loosen them enough to take all pressure off the spring so you can begin taken the plate/tophat off.
these are the wrenches you'll need. this is the stock non-adjustable BC Racing tophats. first step will be taken the dampener adjuster off and the main nut the holds the plate on. when you get the dampener adjuster off you will expose a 6mm allen..this is used to hold the stud still while taking off the 17mm nut.
next you will want to slide off the collar that sits around the stud. once the collar is off you can slide the plate off.
here is a pic of the plate completely off. now we will start to install the new adjustable camber plates.
put the new camber plate on. then slide collar back around the stud. tighten down the 17mm nut. you will need to use the allen wrench again to hold the stud from spinning. reinstall the dampener adjuster with your 14mm wrench.
now the camber plate is completely installed. while trying to put the coilver onto the car i noticed that one of the small allen bolts was hitting on the side of the fender hole.
to solve this problem you need to move both outside allen bolts to the middle slot.
this is what the allen bolts should look like once moved over.
now the coilover will slide back up into the fender and bolt right in with the 3 12mm nuts that hold the coilver to the fender.
Hope that helps all of you out that will be doing this mod in the future when these plates come onto the market.
Justin Grimm
GrimmSpeed
post #49 of 194 Old 09-21-2007, 12:43 AM
Dang man, another excellent write up. Looking forward to see the final product.
post #50 of 194 Old 09-25-2007, 12:04 AM Thread Starter
obx rear adjustable trailing arms came today. i was a little worried since they were only 120 shipped but to my surprise these puppies are pretty solid. they have a pillow ball mount on one end..that same end is also adjustable.
install was pretty easy...1 bolt to the hub, 1 bolt to the trailing arm bracket, and 3 bolts that hold the trailing arm bracket to the car.
of course..the pics:
GrimmSpeed
post #51 of 194 Old 09-25-2007, 02:28 AM
hesh_one's Avatar
hesh_one is an unknown
oh so pretty
hesh_one is offline
post #52 of 194 Old 09-25-2007, 12:49 PM
damn...if your not thinking of possibly showing this car...you should. tricked out all the little stuff.
post #53 of 194 Old 10-02-2007, 01:47 AM Thread Starter
yeah i'm sure we'll bring it to a few shows.
wrx wiring harness all chopped up to be implanted into the L
GrimmSpeed
post #54 of 194 Old 10-02-2007, 01:53 AM
king723 is an unknown
this is probably the best write up on this forum..its awsome seeing your project come a long! major props again man..
king723 is offline
post #55 of 194 Old 10-02-2007, 10:50 AM Thread Starter
thanks! just trying to help out anyone else that is wanting to do this huge project.
got most of the wiring run through the car. the only piece i'm missing is the 'fuel tank cord' so i need one of those asap.
looks weird looking at the engine bay only cause its starting to look just like the wrx.
GrimmSpeed
post #56 of 194 Old 10-02-2007, 12:05 PM
Longshot's Avatar
Yeah man nice job with this writeup so far. Glad to see such a large project laid out with tons of pics. I really can't wait to see it when it's done, gonna be crrraaaazzzzy. Mad props.
DTRacing Tuned
Longshot is offline
post #57 of 194 Old 10-02-2007, 05:38 PM
you should be commended for laying this project out so well and planning a reasonable order to things from the start. Most people who get into this type of project have only a vague idea of what they're in for and do things as they get the parts rather than systematically. Your process is a wonderful example to follow for this type of build.
Keep at it!
post #58 of 194 Old 10-03-2007, 12:13 AM Thread Starter
thanks for the kind words guys! keep checking the thread as i'll keep posting up the updates as quickly as i can.
Thanks to one of our newest sponsors L&E Fabrication we just got a bunch of goodies in the mail...
we received basically every bushing you can get for the suspension components and cross members. we also received the whiteline rear xmember locking bolts which i cant seem to get in yet because the threads on the car are all messed up since there wasnt a plug on the hole to stop them from rusting to all hell.
some pics of the lateral link bushings. these bad boys go on specific ends so make sure to read the directions before installation.
We used a press to push out the oem bushings and push in the new bushings. the process is a tad bit tedious and i vividly remember dropping a few f-bombs. most of the oem bushing can just be pushed out but there are a few that need to be cut out because there is a metal sleeve that cant be pushed out...one of these spots is on that bracket that holds the rear diff up(this bracket bolts to the rear xmember).
all in all the bushings are much stiffer compared to the mushy stock ones.
We also received another part that i'm very excited about...here it is in the box. Anyone know what it is?
Thanks to our new sponsor, L&E Fabrication. Their products can be found at http://www.landefabrication.com/
Justin Grimm
GrimmSpeed
post #59 of 194 Old 10-03-2007, 12:56 AM
part of a driveshaft?
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #60 of 194 Old 10-03-2007, 03:41 PM
surfwalden's Avatar
surfwalden is an unknown
Send a message via AIM to surfwalden
i love watching this project come alive. It is also like a game show... Grimm puts a box out and lets us guess whats inside. If we guess whats inside to we get a prize? (LOLOLOL)Keep up the posts and pics. It might get me motivated to start a project, but mine would be a lot slower!!!
surfwalden is offline
