greddy type-s bov, not ## usual sound, do u have this problem? - Subaru WRX Forum
post #1 of 12 Old 07-04-2006, 10:26 PM Thread Starter
k so heres my issue...
i installed the bov and its dumping in the atmosphere(save the lectures) now when u rev it up, u can here the trademark loud high pitch whistle, but when u shift its jus makes a low pitch "pssshhht" kinda like the mopar srt-4 bov but quieter and when i had my lancer and my bov was recirculated it was louder and it gave that cool trademark sound when shifted ....but i only get it when i rev it...
anyone know why or do they get that same problem. Everyone says its really loud, i dont get that...
HELP ME OUT GURU'S THANKS
Blue_By_You is offline
post #2 of 12 Old 07-04-2006, 11:06 PM
trek98xc's Avatar
Send a message via AIM to trek98xc
Sounds like its not opening up all the way. Does is soud off fully when you are getting on it?
rob
▼SbiΣ Mi▼
trek98xc is offline
post #3 of 12 Old 07-05-2006, 04:56 AM Thread Starter
it doesnt flutter if that is what u think
post #4 of 12 Old 07-06-2006, 09:53 PM
oldfartracer's Avatar
What is your boost level? The higher the boost the louder it should be, if you have it adjusted right.
Are you using the same BOV you used on the Lancer? If so did you change the spring? To run atmospheric you need a stiffer spring than the recirculated one.
oldfartracer is offline
post #5 of 12 Old 07-06-2006, 10:33 PM
Send a message via AIM to al5dsm
You dont adjust a Type S but replacing the "Spring". My guess is that the BOV is not adjusted properly. It sounds like it is too tight. Try loosening it up a bit and going for a drive. The Type S on my single turbo'd Supra is pretty loose.
al5dsm is offline
post #6 of 12 Old 07-07-2006, 11:55 PM
JiveMasterT's Avatar
Remember, the sound will be different depending on how much air is exiting the valve. My friend's Greddy Type S sounds similar to what you're describing but there is also a high pitched sound to. I'm with everyone else here, it sounds like it's too tight or too loose... try playing with the adjustment.
Patrick - 2007 STi Limited
▼SbiΣ Mi▼
JiveMasterT is offline
post #7 of 12 Old 07-08-2006, 12:11 PM
9d2TSi's Avatar
The thing about the type S is, unless you're utilizing both nipples on it, you're not going to have much adjustability.
9d2TSi is offline
post #8 of 12 Old 07-08-2006, 09:17 PM Thread Starter
my buddy who adjusted said if we loosen it up n e more were gonna cause boost leaks
ummm but im in Las Vegas right now and i bought a turbo xs RFL one
now switching the blow off, i jus put it on the flange and do i jus hook up the vac hose to the top part of the RFL?? anyone know the install on this
post #9 of 12 Old 07-08-2006, 10:21 PM
Yeah that's correct. Should have gotten the H34 so you could recirculate it though...
▼SbiΣ Mi▼
post #10 of 12 Old 07-09-2006, 01:23 AM Thread Starter
ya but im dumping it into the atmosphere so i dont need that, and in winter im switching back to stock, jus incase
post #11 of 12 Old 07-09-2006, 01:24 AM Thread Starter
thanks jive for confirming that for me...!!! Much apprecitated!!
post #12 of 12 Old 07-09-2006, 11:08 AM
No problem! Hope it all works out for you.
▼SbiΣ Mi▼
