» Sponsor Links
»Garage Storage and Cabinets
Old 04-16-2008, 02:18 PM   #1 (permalink)
Car: 01 Jetta 22psi
Reputation: Scooby_WRX04 is an unknown
Is this a good exhaust set up?
Cobb 3in DP (Catted) Invidia N1 exhaust 3in And whats a good UP?
Old 04-16-2008, 02:24 PM   #2 (permalink)
Longshot's Avatar
Car: 05 WRX
sounds good, should be nice and loud. I'd look into any UP without a flex section....I personally like my Invidia.
DTRacing Tuned
Old 04-16-2008, 02:28 PM   #3 (permalink)
Car: 01 Jetta 22psi
sweet lol thats what im looking for the loudness, if i get an uncatted Up Pipe can you still pass inpection? and what will i need to do in order to get rid of the cel that i will get when thiss is on?
Old 04-16-2008, 02:44 PM   #4 (permalink)
Longshot's Avatar
Car: 05 WRX
Emission = different for every state. NY is tight and I'm not sure if you'll pass with an aftermarket cat. From what I've read here in CT it's fine but once again refer to NY inspection specs for that. For the CEL you can disable it with EM, or a mechanical fix like a resistor in the connector of the EGT (plugs into oem UP).
DTRacing Tuned
Old 04-16-2008, 02:55 PM   #5 (permalink)
Car: 01 Jetta 22psi
Cobb AP do the trick?
Old 04-16-2008, 02:58 PM   #6 (permalink)
Car: 01 Jetta 22psi
well where i go to get my car inspected the guy doesnt check the exhaust or anything on my jetta i have an after market cat and it still passes
Old 04-16-2008, 03:01 PM   #7 (permalink)
Longshot's Avatar
Car: 05 WRX
AP will do the trick, and you should be all set then
DTRacing Tuned
Old 04-16-2008, 03:03 PM   #8 (permalink)
Car: 01 Jetta 22psi
ha sorry one more question does it matter if the uppipe is catted or not?
Old 04-16-2008, 04:00 PM   #9 (permalink)
Longshot's Avatar
Car: 05 WRX
yes, you want no cat
DTRacing Tuned
Old 04-16-2008, 04:18 PM   #10 (permalink)
You want to look for a catless aftermarket uppipe... the main reason you replace your uppipe is to get rid of the pre-turbo catalytic converter so it doesn't fall apart over time and send bits of metal directly into your turbo causing turbo failure and other engine damage in most cases involving higher than stock horsepower. It's important to note that most people don't report any problems running Stage 2 power setups with their stock catted uppipes, but generally, if you are planning to advance past Stage 2 power-wise, the catless uppipe is a preventative safety mod. Most uppipes are slightly larger in diameter too, so your turbo will also spool slightly faster.
07 WRX - Cobb AP Stage 2
Old 05-04-2008, 11:32 AM   #11 (permalink)
Car: 05 WRX
Reputation: mikeb01453 is an unknown
alright hate to sound like an idiot but im new to the world of FI, ive always been an NA guy but thats besides the point, im looking into doing an exhaust system but i dont understand exactly what a catted down pipe is, like i said i apologize for the dumb question but this is something all new to me, thanks for the help though
Old 05-04-2008, 12:48 PM   #12 (permalink)
The downpipe is what is attached to the exhaust side of a turbo. The stock DP is the biggest restriction in the 02-07 WRX exhaust track. Best design to look for when purchasing a DP s a bellmouth. Catted vs non catted is a personal preference (with about a $100 difference also) and emissions standards for your state. CobbTuning.com - Exhaust Design is pretty much my thing to put up when people ask about exhausts. It explains a little about it all.
"Stage 2, not so cool anymore, starting to get bored now."
Old 05-04-2008, 08:17 PM   #13 (permalink)
Car: 05 WRX
thanks man appreciate the pointers
Old 05-05-2008, 04:43 AM   #14 (permalink)
Not a problem, thats what we are here for.
Old 05-14-2008, 05:27 PM   #15 (permalink)
Reputation: jpseeber is an unknown
I would suggest getting the year appropriate accessport from cobb as this will give you tunning options for your car and help with those pesky lights. any one running a header? I just cant find any results. I guess my old "big chevy with headers" mentality is coming back.
