Going Stg 2 - Subaru WRX Forum
post #1 of 6 Old 03-15-2008, 01:02 PM Thread Starter
tom_noland's Avatar
Send a message via AIM to tom_noland Send a message via Yahoo to tom_noland
Going Stg 2
I was wondering about the metal gaskets for the Dp. Are they important to replace when putting a used Dp in?
Tom
'05 WRX Wagon (RIP)
Cobb AP Stg 2
RIP baby....Here I come STi.
Stupid deer.
tom_noland is offline
post #2 of 6 Old 03-15-2008, 01:14 PM
Longshot's Avatar
Yes sir you should always use new oem gaskets (can get them just about any suby parts webite or the dealer). Get the 5 bolt gasket for the DP-Turbo connection and a 3 inch two bolt donut gasket for the DP-Midpipe connection.
DTRacing Tuned
Longshot is offline
post #3 of 6 Old 03-15-2008, 04:00 PM
Some people will say it's ok to use the one you already have on your car. Some people will say it's a good idea to get a new one. Personally, I bought a new one when I put my aftermarket downpipe on my 07 WRX with 11,000 miles (give or take) since the gasket looks like it's layered and it crushes slightly when torqued. I'm a believer that it's always a good idea to use new gaskets. Besides, it's not terribly expensive. What do you have to loose, besides possibly an annoying leak?
post #4 of 6 Old 03-15-2008, 06:34 PM
zmanoside's Avatar
Correct me if I'm wrong but it depends on what DP you are putting in. I'm pretty sure the Cobb DP uses the OEM donut gasket, but I have an Invidia DP that came with a flat gasket that I used....so it depends on your setup...but all in all yes replace the gaskets, might as well since u r in there anyway. Z
12.7 @ 109
zmanoside is offline
post #5 of 6 Old 03-15-2008, 08:09 PM
Friendly correction: the Cobb downpipe is cleverly designed to use either a factory-style donut gasket or a 3 inch, 2 bolt flat gasket to accomodate almost every different type of cat back on the market for our cars or the stock one. ...the APS 3.5 inch cat back might be an exception
post #6 of 6 Old 03-16-2008, 07:29 PM Thread Starter
tom_noland's Avatar
All done with the install. We swapped and everything came out fine. I didn't get the chance to gut the up-pipe soi am takig it easy oh her til' I do. Unless i dont have too. From everything i have read you need to replace the up or gut it.
Tom
'05 WRX Wagon (RIP)
Cobb AP Stg 2
Stupid deer.
