Gates or Dayco WP kit.? - Subaru WRX Forum
post #1 of 6 Old 02-18-2013, 05:58 PM Thread Starter
AllExtinct's Avatar
Looking around for Water pump kits since I'm over 100k now and don't want to run into any problems down the road.
Found the Dayco kit and was looking for reviews on it and didnt find to much but found some hit and misses on Gates.
Wondering if you guys got any opinions to throw out here?
Want to make sure I go the right route for this since its pretty much do or die if something happens.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #2 of 6 Old 02-18-2013, 06:00 PM
06_hawk_eye's Avatar
06_hawk_eye is an unknown
I went with Subaru oem water pump,timing belt and tensioner
Sent from AutoGuide.com App
06_hawk_eye is offline
post #3 of 6 Old 02-18-2013, 06:24 PM
boo-key's Avatar
^ +1 for oem
boo-key is offline
post #4 of 6 Old 02-19-2013, 06:32 AM
Gates. The new kits have the mark on the belt which helps considerably.
post #5 of 6 Old 02-19-2013, 04:42 PM Thread Starter
AllExtinct's Avatar
The only thing I saw negative about Gates was the blue belt wear on the pulleys.
But the kit I saw had a black belt so maybe they are older belts?
Also I read some people reuse the WP gasket because the one in the kit is a some what cheap replacement?
JDM ej205 swap.
Home state: PA Crew
Chuck.
post #6 of 6 Old 02-19-2013, 05:56 PM
No feedback there... you've prob done more research on that than I.
