-   -   fuel pump? (http://www.wrxtuners.com/forums/f52/fuel-pump-49209/)
thekamikaze kid 05-14-2014 03:58 PM
fuel pump?
After asking many tuners advice on going stage 2 with my 03 wrx i have been told that i 100% need a fuel pump and should do the same with any wrx under a 08. I was told without one the car would eventually lean out and fry the pistons. what do you guys know about this and which one should i get?
I was also told a 3 port ebcs would make for a better tune but could get one without. any advice?
thanks in advance.
thekamikaze kid 05-14-2014 04:11 PM
Btw these are e tuners and would not profit at all if I buy these parts
boo-key 05-14-2014 04:24 PM
549 Attachment(s)
Your talking $200 for both. Do it!
thekamikaze kid 05-15-2014 10:42 AM
Any ideas on which ones to get? I have heard that the walboros tend to fail...
boo-key 05-15-2014 11:38 AM
549 Attachment(s)
I would go with a grimmspeed ebcs. I have a walbro and it still runs strong. Most pump failures are due to Chinese knock offs or low fuel levels. The fuel also cools the pump so when it gets low they can burn up. Just don't go below a quarter tank. I think aem makes a drop in fuel pump also but I've never heard much about it. Some known trusted ones are walbro, deatschworks, aeromotive, and Bosch. Although not necessary at your power levels, if you really want to take full advantage of the pumps capabilities you can rewire it with bigger gauge wire. Many people overlook this.
arcticscythe 05-15-2014 11:40 AM
deatchworks makes some really nice fuel pumps, and they come with a spreadsheet showing their testing parameters and final output. As for the BCS I like Grimm-Speed, their hardware is really overbuilt.
thekamikaze kid 05-15-2014 12:05 PM
thanks guys! one last question, would you guys trust a local mechanic to put in the downpipe and fuel pump, or is it always a good idea to bring it to a performance shop?
onethirtyeight 05-15-2014 03:31 PM
IMO is would trust a local mechanic as long as they are trust worthy. lol I know that sounds funny, but just because somebody labels themselves as a performance shop does not mean that they are great mechanics. It only means that they are targeting a certain client and [U]maybe[/U] that they actually specialize in performance part installation. A down pipe should not be difficult for any seasoned mechanic. I guess bottom line for me is take it to a shop that you consider trustworthy and has a good reputation, not just someone who claims to be specialized in a certain area.
arcticscythe 05-15-2014 03:54 PM
I cant speak for your local garage but I always prefer to work with performance shops when that's an option. I usually grab them a coffee or a 6 pack and shoot the breeze with them while they hook me up. Neither are particularly hard to install youurself but you will need access to a lift to do the downpipe. Id take it to a performance shop just so you can hang out for the hour it takes to do those installs
boo-key 05-15-2014 04:19 PM
549 Attachment(s)
Any competent mechanic can install these. They are relatively easy installs. If have any mechanical inclination at all you should be able to do it yourself as well. No lift needed. I did my whole turbo back and ewg off jackstands in my garage. Granted, a lift does make everything easier but is not required. Just remember to also get new dp to turbo gasket, appropriate gasket for the other end of the dp, and you might even need a new gasket for the fuel tank access since your car is over 10 years old. I think that one will come with the pump install kit if you opt for it.
thekamikaze kid 05-15-2014 07:27 PM
thanks again guys!
btw onethirtyeight where did you get those awesome headlights? are those morettes?
man show 05-15-2014 09:40 PM
I've had my GrimmSpeed 3 port EBCS and Walbro 255 LPH fuel pump for ~2 1/2 years (~50k miles). Although I generally try not to, sometimes I run my gas tank below 1/4 - it happens :) The fuel pump can be upgraded any time without a tune (it's not a requirement for Stage 2 vehicles, but it's pretty much required once you move beyond that). The EBCS needs a tune, period. The fuel pump is easy to do if you have some basic hand tools and a little time. The dp can be a little tricky if the bolts are stubborn, but it's doable if you have a jack, jack stands, and basic hand tools - the O2 sensor is the trickiest part, but you can usually borrow an O2 sensor socket from your local auto parts store for free if you need it. Always use new gaskets.
thekamikaze kid 10-22-2014 08:22 PM
ok im probably going to get all my stuff done at elite in goshen and will soon be buying parts. ive decided to add a catless up to my long list of parts. i noticed man show said to get new gaskets, wondering how much those are for the up and dp. (ballpark anyway) also do i need to buy a install kit with my walboro 255lph fuel pump if i have it installed by a shop? thanks in advance.
Brockton 10-22-2014 09:25 PM
[url=http://www.rallysportdirect.com/Walbro-Fuel-Pump-Kit-255lph-Subaru-WRX-STI-2002-2007]Walbro Fuel Pump Kit 255lph Subaru WRX / STI 2002-2007 GSS342 400-791 at RallySportDirect.com[/url]
There you go
Something to think about is the walbro is a bit noisy, the DW pumps are quieter
thekamikaze kid 10-22-2014 09:41 PM
fuel pumps make noise now??? I was unaware. thanks brockton since i posted i found that [url=http://www.proimporttuners.com/]Import Parts Source at PRO Import Tuners[/url] give us discounts for being members. i think that the fuel pumps are listed at five bucks less at their website b4 the discount. is the noise the walboros make enough to switch to a deatchwerks pump? because i have also heard that the walboros burn up, and that the DW were better.
