the fp green is to much turbo for a stock wrx block.. if you built the motor the block is still an open deck block and isnt good for high psi levels.. also running the green at 17psi is a waste of time, this turbo starts makeing power around 23psi+.. i would either get a built usdm sti block or a jdm sti block, if you want to run this turbo. also you will need a fmic for a turbo as big as the green. the green isnt a small turbo if you put it on a stock wrx block you will blow up the block. i havent heard of anyone with a wrx block haveing thier motor last long with a green. if you want a bigger turbo go with a 18g, vf22 ect.
