fmic - Subaru WRX Forum
post #1 of 22 Old 02-10-2008, 08:59 PM Thread Starter
hi-power WRX's Avatar
hi-power WRX is an unknown
fmic
hey guys can the stock turbo..can handle an after market fmic? because im thinking of buying an fmic, but im concern. i only have tbe, and i like how it looks,,thanks guys
hi-power WRX is offline
post #2 of 22 Old 02-10-2008, 09:04 PM
tom_noland's Avatar
tom_noland is an unknown
Send a message via AIM to tom_noland Send a message via Yahoo to tom_noland
what all have you done so far? ### just a FMIC will drop your pressure.
tom_noland is offline
post #3 of 22 Old 02-10-2008, 09:09 PM Thread Starter
only tbe..n a k&N drop filter.....n i want 2 get an fmic, but im concern...
post #4 of 22 Old 02-10-2008, 09:21 PM
tom_noland's Avatar
Sure it looks cool but you have to have an upgraded turbo, injectors, fuel pump, and some kinda EM to be able to push enough pressure through the long tubes and huge intercooler.
post #5 of 22 Old 02-10-2008, 09:33 PM Thread Starter
ohhhh dammm...so i think just go with the tmic....because i only have tbe, drop filter, n im not thinking of upgrading the turbo n all of that, so just go wit that right. thanks
post #6 of 22 Old 02-10-2008, 10:54 PM
As stated above, if you dont plan on upgrading the turbo, and dont want added lag a FMIC isnt really for you then. But if you get a TMIC and a map or tune for it, you can get some gains for the car.
post #7 of 22 Old 02-10-2008, 11:05 PM Thread Starter
you think...what if i just trow it in...with no map...u think its the same...or i need 2 tune
post #8 of 22 Old 02-10-2008, 11:09 PM
Im sure it will function for the most part. But with something like either IC you wont really see a gain from the cooler/denser air until you tune for it.
post #9 of 22 Old 02-11-2008, 10:04 AM Thread Starter
ohhhh i see. so i need to get the cobb thing...right
post #10 of 22 Old 02-11-2008, 12:16 PM
tom_noland's Avatar
Yeah that and a couple of different things
post #11 of 22 Old 02-11-2008, 01:59 PM
Rob@CSS is an unknown
We can get you a TMIC kit AND a Cobb AP for what you would pay for a fmic normally. Pm for details. Hope we can help!
Rob@CSS is offline
post #12 of 22 Old 02-11-2008, 07:03 PM
tom_noland's Avatar
For the stock turbo the TMIC is your best bet.
post #13 of 22 Old 02-11-2008, 09:25 PM Thread Starter
ohhh thanks guys///
post #14 of 22 Old 02-11-2008, 11:44 PM
VanillaJuice's Avatar
VanillaJuice is an unknown
Send a message via AIM to VanillaJuice
i put a ssautochrome TMIC on my car.....i used a free stage 1 map....the intercooler doesnt get hot like the stock one did...which was always...
Opensource tune by CAMTuning.com
Parts from Jeremy at Crucial Racing
VanillaJuice is offline
post #15 of 22 Old 02-12-2008, 05:26 PM
digmaster is an unknown
Send a message via AIM to digmaster Send a message via MSN to digmaster
i had a ssautochrome tmic on my p and p stock turbo 04 wrx. i ended up trying to max out my stock turbo and i end up switching to a fmic because it would get heat soaked. i also didnt feel that much lag like alot of people say it does. yes it does have some but just with the increase in power it makes up for it. also i didnt have injectors i did put in a fuel pump. my mods were perrin short ran intake and turbo inlet, ported and polished stock turbo, turboxs fmic, ported and knife edged tb, ported intake manifold, ported and delete tgvs, ebay unequal lenght headers reweld, greedy up pipe with a 38mm external wastegate, hks down pipe, 3' rsr cat back, fuel pump and a turboxs utec. i was running 21psi tapering to 19 psi by redline with meth injection. i made 278whp. and with the tmic i was only able to make 263 whp for one or two runs after that power would drop like crazy cause of heat soak even with the meth. the problem with big tmic is that most sit right over the turbo and not to mention the engine to lol. i guess if your not planing to break any records or make a ton of power a ebay tmic will do.
digmaster is offline
