» Sponsor Links
»Garage Storage and Cabinets
Old 09-11-2007, 09:34 AM   #16 (permalink)
Reputation: T-Money is an unknown
What if I don't have a dyno within 600 miles? So if I get a walbro 255l fuel pump, 650 cc. injectors, Catless up and down pipe (already have cat back), and a 16 G evo III turbo would that be a good set up? The only thing is I dont know what to do about EM and thats the first thing I want to buy. Can anyone help?
Thanks
Old 09-11-2007, 12:29 PM   #17 (permalink)
if you don't have a dyno within 600 miles, I'd look into "online tuning" where they send you a map, you put it on and log it, and then they tweak it based on the logs. That way you get something that actually runs well.
The rest of your parts list is fine.
Engineers can't spell, sorry!
Old 09-11-2007, 04:02 PM   #18 (permalink)
What EM should I get and where do I get the online dyno map? Any links
Thanks
Old 09-11-2007, 04:55 PM   #19 (permalink)
KHoff7's Avatar
Car: 04 WRX
Reputation: KHoff7 is an unknown
www.xpttuning.com is a good forum for subaru ecu tuning and theres a link at the top for the guy who sells the staged maps for them
Old 09-12-2007, 01:05 AM   #20 (permalink)
Can some one tell me about the whole flashing thing. I know this is a dumb question, but there are so many diff EM and maps and flashing. Its all so confusing, i would like to learn more about tuning before i start to mess with my car under the hood because as i found out scoobys are very testy. I want to learn how to tune it without a dyno, by myself. Can some one teach me? Thanks for the help
Old 09-12-2007, 02:41 AM   #21 (permalink)
WRXforME's Avatar
Car: 04 WRX
Reputation: WRXforME is an unknown
Well if you really dont have a dyno/tuner within 600 miles of where you are, you can either considering learning to tune yourself, which can be complicated if you dont know what you are doing. Or you can go the 600+miles to a tuner.
With the mods people are suggesting, and the FMIC you already have, you NEED Engine Management. Theres no ifs or buts about it. Its a must have and should be your next purchase. To complete a turbo upgrade (for the 02-05 WRX's), you will need the Turbo, bigger injectors(the cc's of the injector depends on the size of the turbo), a fuel pump (walbro 255 fuel pump is the most common and fairly cheap, and Engine Management. Those are the minimum requirements to an upgraded turbo. You already have a FMIC, for a turbo the size you are looking for (a turbo that gives a slight more HP, not something crazy), the FMIC is a little much, but, you can be tuned for it. So you already have it, you might as well keep it, you just will have a little more lag than a TMIC.
The size of injectors I would recommend for a 16g or BIG 16g would be around 650cc. 650cc will flow very nicely for either of those turbos. STi 'pink' injectors, which are 550cc, would probably also flow enough for the 16g but going bigger is always better than smaller with injectors. You cant buy 'too big' injectors.
Another thing some people upgrade while doing turbo upgrades is the fuel rail. Some people say its necessary, some say its not. Im going to be doing an 18g turbo upgrade soon and Im leaving my fuel rail stock.
Now on to Engine Management. There are 4 main, most popular forms of it.
1) Cobb Accessport
2) UTEC
3) EcuTek
4) OpenSource
1) The Accessport is by far the easiest form of EM. You quite literally plug it under your steering column into the OBD-II port and you 'flash' your ECU with a new base map. The Accessport comes with a few maps on it, you can also download other maps off the internet if it is a closer match to your car. The most popular map for the AP would be a Stage II flash (on either 91 or 93 octance gas). Someone who flashes to stage II would have a Turboback exhaust (downpipe and catback), and the AP. Thats all someone needs to be at stage II. The Accessport is custom tuned with another device called a StreetTuner. I have no experience with it but it is how a custom map is created for your car by a qualified tuner, or by yourself if you know what you are doing.
2) UTEC - I believe it stands for User Tunable Engine Computer, or something close to that. UTEC is the most expensive form of EM, but, also provides the most options to the tuner and thus usually giving the best possible results. Im much less familiar about UTEC but I believe its a 'piggyback' device that sits on or next to your cars ECU and by doing so, it controls it.
3) EcuTek - Another form Im not completely familiar with. People who have it, love it. If you want good info on it, ask Ian. Hes a moderator and can explain it much better than me.
4) Opensource - This is the newest form of EM. Its also the cheapest. And by far the best bang for buck. It works the same way as the Accessport, using the OBD-II port, except instead of buying the actually Accessport device, you just buy a Tatrix cable and you need a laptop with some software you can download. The full How-To on Opensource can be rear here http://wrxtuners.com/forums/showthre...ensource+cable
Hope this helps ya alittle.
Old 09-12-2007, 11:20 AM   #22 (permalink)
No. He has another choice. He can get a tuner to do it for him remotely as long as he does the reflashing and logging (not hard).
OP: you need to call up an "online tuner" and talk to them. It's not complicated really. They send you a base map and you load it. Then you run your car a bit and log the results. They update the map and the process continues until you get something good. All you have to know how to do is load and log. It's not rocket science. Your car has an ODB-II port so with the right cable, you can plug the car into a computer.
Old 09-12-2007, 02:39 PM   #23 (permalink)
Reputation: superman 44 is an unknown
i have an 02 and i bought it and it has catback and cold air intake and 20psi the dealer said i had injectors but i dont know what kind and i was thinking about getting the AP and up and downpipe is that good or what should i do
Old 09-12-2007, 03:10 PM   #24 (permalink)
If you are already at 20PSI something has been done to your car that probably isnt in its best interest. And the CAI isnt helping much either, you should probably look into a pro tune. The AP isnt going to help much since you already have bigger injectors in the car.
Online
Old 09-12-2007, 04:05 PM   #25 (permalink)
So should I just get my stuff I want (turbo, Fuel pump, 650 cc injectors ect.) Install it and then get a remote pro tuner to help me out with a map and opensource tune it with that cable and a laptop?
Thanks for all the help
Old 09-12-2007, 04:15 PM   #26 (permalink)
Sounds like your best bet.
Online
Old 09-12-2007, 05:13 PM   #27 (permalink)
Reputation: wrx0287 is an unknown
keep in mine once you do all this you should be pushing around 300whp and your tranny will go very easy if not to careful, so start saving for your trans upgrade
Old 09-13-2007, 04:04 PM   #28 (permalink)
Ok I found out what im going to buy, tell me if this is ok before I make any choices
FMIC
Turbo XS RFL BOV
650 cc injectors
1 step colder spark plugs
cobb short ram intake
Tactrix cable
Custom map made by online tuner? Any other suggestions?
Thanks
