-   -   A/F gauge (http://www.wrxtuners.com/forums/f52/f-gauge-31074/)
Ridge10 07-20-2011 08:31 PM
A/F gauge
I just made a three pod gauge out of my clock and I got the boost hooked up, and I need to go get a piece for my oil press. gauge, but my a/f gauge is just siting on the table. I kinda have an idea of how it goes in, but I dont know for sure. I know I have to weld in (or is JB weld good? Im pretty crafty with some JB weld), but where? How far down the downpipe. And those four wires in the pic. I know power, ground, and dimmer, but whats the white wire with the connector for? Where do I plug that in at? It says wide band analog output 0-5v. It would be great if I could get some guidance from someone that has already done this. Thanks!
psinuse 07-21-2011 05:09 AM
[quote=Ridge10;264627]I just made a three pod gauge out of my clock and I got the boost hooked up, and I need to go get a piece for my oil press. gauge, but my a/f gauge is just siting on the table. I kinda have an idea of how it goes in, but I dont know for sure. I know I have to weld in (or is JB weld good? Im pretty crafty with some JB weld), but where? How far down the downpipe. And those four wires in the pic. I know power, ground, and dimmer, but whats the white wire with the connector for? Where do I plug that in at? It says wide band analog output 0-5v. It would be great if I could get some guidance from someone that has already done this. Thanks![/quote]
The white wire is for heating the O2 sensor I believe. I put mine in the rear O2 sensor spot when I'm tuning. Seems to be the right place for my car though. I know alot of guys put them right in the mouth of the DP.
Ridge10 07-21-2011 11:12 AM
So I dont have to drill in my exhaust? I can just put it there?
psinuse 07-21-2011 03:13 PM
[quote=Ridge10;264650]So I dont have to drill in my exhaust? I can just put it there?[/quote]
I'd go by the recommendation of the manufacturer of your Wide Band. Some will tell you how close to put it in the exhaust for the best results. Like I said it works for my car and several others that I have tuned, but then again maybe I have just gotten lucky all these years...:p
Ridge10 07-21-2011 03:38 PM
Lol hopefully some luck will rub off. And the white wire, where do I connect it to?
psinuse 07-21-2011 04:19 PM
[quote=Ridge10;264680]Lol hopefully some luck will rub off. And the white wire, where do I connect it to?[/quote]
Did it not come with instructions? What brand is it?
Ridge10 07-22-2011 02:46 PM
Depo. They dont seem that cheap. I wired up the boost and its pretty good. I just dont know why the white wire is coming off the gauge with the powe, ground, and dimmer.
Ridge10 07-22-2011 02:47 PM
And if I do put it in the stock o2 place...What do I do with the stock o2 sensor?
psinuse 07-22-2011 02:58 PM
It should be disabled with your software.
Okay what a minute I think I miss understood what you are wiring in. Are you wiring up the gauge or the actual sensor itself?
If it's the gauge then there should be a red, white, black and violet color wires correct?
Ridge10 07-22-2011 03:23 PM
Ok, coming off of the gauge, there is two ports. One connection goes to the sensor harness and that goes to the sensor, and that goes in my exhaust. And in the other port, there is a black, white, red and orange wire. I hooked up the other gauges but its the random white wire on this gauge thats giving me problems. It says Wide Band Analog Output...Im guess I just leave it unpluged cause it has a bullet connector ( female) on it. Is it used for tuning? Does it plug into a controller?
Ridge10 07-22-2011 03:25 PM
And sorry if Im hard to understand lol. Im just overloaded with different things Im researching....I need to start writing stuff down.
psinuse 07-22-2011 03:39 PM
Your not hard to understand, just my reading comprehension is horrid at my age...lol
Give me a few I have to head to my second job in a bit. I will try and figure it out, but I think the white wire would be for using a AEM unit, or some type of standalone type EM.
Ridge10 07-22-2011 03:59 PM
Ohh, that would make sense since it says to "controller power harness". I just dont want to get my car all put back together and have a wire loose in there that should be connected to something.
