exhaust leak question - Subaru WRX Forum
post #1 of 6 Old 03-03-2005, 03:01 PM Thread Starter
RPFRIDE's Avatar
RPFRIDE is an unknown
This morning i started to hear what i believe is an exhaust leak in the area of my turbo. She is not loosing boost and sounds like ass when i start to give her gas. Im thinking it is the downpipe side of the turbo. Any other suggestions?
I went ahead and ordered both gaskets (up and down) from scooby tuners (one of this forums great sponsors). Very nice fellows. I also ordered the sti hood scoop (about time).
She is up for inspection soon and ill have my mechanic fix her up nicely.
RPFRIDE is offline
post #2 of 6 Old 03-03-2005, 04:14 PM
al5dsm is an unknown
Send a message via AIM to al5dsm
Yeah its most likely leaking from the gaskets. The new ones should fix it. When I installed my downpipe I didn't have the catback to downpipe gasket tightened all the way and had a nasty exhaust leak. They sound horrible dont they Good luck with it.
al5dsm is offline
post #3 of 6 Old 03-03-2005, 06:04 PM Thread Starter
RPFRIDE's Avatar
Thanks. Curious thing is, im pretty sure it happened after i had my car washed yesterday. Im not sure because i do listen to the radio much and the exhaust is loud. I realy hope it is nothing worse , ig cracked turbo, uppipe..from cold water and hot engine.But she is still running well with fine power and i hit over 18lbs of boost tonight in first gear.
RPFRIDE is offline
post #4 of 6 Old 03-03-2005, 10:48 PM
Yeah hopefully nothing cracked but I'm sure your fine. Just replace the gaskets you think might be leaking. If that doesn't do it, spend a day going over everything making sure its nothing serious. Good luck with it
al5dsm is offline
post #5 of 6 Old 03-04-2005, 09:25 AM Thread Starter
RPFRIDE's Avatar
Ok, it was sunny this morning and i was able to see well under the hood. i notice a nut missing on the uppipe .
il looks easy to get to but didnt want to mess around because im not into branding by turbo.
**I need to know what size and thread type this nut is. Please. Also, do you think i should take it apart and replace the gasket or just tighten her down and see if it leaks?
Cheers
RPFRIDE is offline
post #6 of 6 Old 03-06-2005, 04:37 PM
Dude... that's so freaking weird. I blew my intercooler hose yesterday because it wasn't tight enough, but when we looked under the hood, we noticed the bolt on top of my turbo missing too...
I think the Suby Gremlins are stealing bolts from our cars... :eek:
