evo lll 16g - Subaru WRX Forum
post #1 of 9 Old 04-29-2010, 07:45 PM Thread Starter
evo lll 16g
I just put a new EVO lll 16g turbo on my 02 wrx and now I know I need to upgrade the fule system but I don't really know what I need. What size injector do I need, will a 190 fule pump work or do I need 255. and one last thing will the stock fule pressure regulator work or do I need an adjustable one. Thanks for any info
dustinswrx is offline
post #2 of 9 Old 04-30-2010, 03:04 AM
thack03's Avatar
get 650cc injectors so you have head room, fuel pump is a question for tuner (but should be used) your fuel pressure regulator should be good, make sure you have the other supporting mods for that turbo, tbe, intercooler, some type of engine management
thack03 is offline
post #3 of 9 Old 04-30-2010, 08:48 AM
You will need a bigger pump for sure. Stocker will go out soon anyways. Did you get a 3port BCS yet ? Pick one up before you get tuned (ask your tuner) which he prefers. Nice charger BTW.
post #4 of 9 Old 04-30-2010, 10:44 AM
GrimmSpeed 3-port FTMFW!
Oh and to comment on the fuel pump. The status quo is the Walbro 255, but AVO also makes one that flows 245 and cost 3x as much... It's apparently a better pump from what I've heard.
post #5 of 9 Old 04-30-2010, 02:57 PM
Walboro 255's are pieces of crap. Buy one anyway.
post #6 of 9 Old 04-30-2010, 05:55 PM Thread Starter
tanks for all the info. I also come across a blown sti motor i don't have the money to rebild but what parts can i use off of that motor to help my car out if any. Im trying to get the motor for $200 again thanks for the info
post #7 of 9 Old 04-30-2010, 09:15 PM
Just about Jack n Sh!t if the motor is off a USDM STI. They're two different engine sizes. If it is a JDM STI engine or EJ207. The you could swap out some stuff, but I can't get into specifics, I don't know enough on EJ207s.
post #8 of 9 Old 05-01-2010, 07:42 AM
blk05WRX's Avatar
I think the heads will fit, but if its that cheap grab the intercooler and injectors off of it. Then you'll just need the fuel pump and bcs before your tune.
2005 WRX Cobb Stage 2
2009 Outback
blk05WRX is offline
post #9 of 9 Old 05-01-2010, 11:43 AM Thread Starter
ill get more specs on what engine it is for sure so i can get some more answers on what i can swap
