EGT sensor - Subaru WRX Forum
post #1 of 4 Old 04-26-2005, 05:02 PM Thread Starter
EGT sensor
hey do any of you guys know the diameter of the threads on the stock EGT sensor???
any info would be helpful thanks
post #2 of 4 Old 04-26-2005, 08:40 PM
WRXtreme's Avatar
Rear o2 sensor is M18 x 1.5, its the same as alot of oil drain plugs and I believe the same as the spark plugs. Not sure about the front, but I think that is the same as well.
WRXtreme is offline
post #3 of 4 Old 04-27-2005, 02:48 PM Thread Starter
thanks for the info but i need to know the size of the EGT sensor
post #4 of 4 Old 04-27-2005, 07:52 PM
WRXtreme's Avatar
So I see, not sure what was running through my head.
I believe the correct answer is 12mm x 1.25, hope that helps.
WRXtreme is offline
