» Sponsor Links
»Garage Storage and Cabinets
Old 08-20-2007, 11:28 PM   #1 (permalink)
atxwrx's Avatar
Club Region: Gulf Coast
Reputation: atxwrx is an unknown
Ebay TMIC
In a couple of weeks I am going to be installing a new uppie, dp and cbe. I figured since I am going to have to take off the IC anyway, I might as well replace it I was looking at a IC on Ebay and wanted to see what luck you guys have had (good or bad) with them. Should I go with that or a "name brand" TMIC? I know that I need new hoses, so that will be purchased too... So, let me know if I should go for it or wait to buy a name brand one....
Old 08-21-2007, 12:29 AM   #2 (permalink)
Strider327's Avatar
Car: 04 WRX
Reputation: Strider327 is on thin ice
Ebay intercoolers are gonna have two problems that you need to look out for.
1. The AC line will rub so you will need to cover it with some type of rubber.
2. The driver side mount will be a pain to line up so be ready to use force.
Other than that you should be okay which whatever one you choose, I would say try to get the cheapest priced one possible and get the y-pipe made for it. Then you'll be good to go. Good Luck.
Old 08-21-2007, 01:01 AM   #3 (permalink)
Club Region: NorCal
Reputation: mystilexzero is an unknown
i was actually considering the same, the cheapest tmic but the biggest one of course, i saw one that was huge, but no hoses, so i decided to get name brand hoses for better quality and decided i might buy samco hoses for 125 dollars.
Old 08-21-2007, 09:49 AM   #4 (permalink)
atxwrx's Avatar
That was the route that I was thinking of going. I wanted to get the Samco hoses and get the larger IC.
Old 08-23-2007, 01:27 AM   #5 (permalink)
wrx3r's Avatar
Reputation: wrx3r is an unknown
i had really good luck with mine. picked it up brand new with y pipe for $150. just got it tuned with 800 cc injectors two weeks ago and i am extremely happy with how much more responsive it feels.
* ignore the random wires in my engine bay i am no master electrician.
bigger and better than ever
Old 08-23-2007, 02:52 AM   #6 (permalink)
HUMANPIE's Avatar
Reputation: HUMANPIE is an unknown
Mystilexzero and Atxwrx, as stated above, you should make sure you get a y-pipe made for that particular larger IC. The Samco IC hose kit is nice, but the y-pipe is designed with the stock IC dimensions in mind.
When I installed my TurboXS TMIC I couldn't use the Samco y-pipe becasue it was about an inch too short to connect to the turbo. So, I had to use the y-pipe they supplied in order to install it.
Wrx3r, what heat shield is that your using?
Old 08-23-2007, 03:12 AM   #7 (permalink)
wrx3r's Avatar
^ its a custom one made by nagyhead from this forum. he lives close so he fabed one up for me.
Old 08-23-2007, 03:51 AM   #8 (permalink)
Club Region: NorCal
oo right on thx for the tip humanpie! btw that intercooler looks nice!
Old 08-23-2007, 04:33 PM   #9 (permalink)
atxwrx's Avatar
Ok, now I am a little worried. Instead of going with the IC with the y-pipe included, I bought the IC and the Samco hose kit. What do you suggest I do? the IC I got is 20x11x4.5. IF you have any suggestions, let me know.
Old 08-23-2007, 04:49 PM   #10 (permalink)
Club Region: SoCal
Trader Rating: (1)
Reputation: WReXd is a helpful contributing member
You can buy a coupler (like a 2" diameter metal pipe) and use it to extend the y pipe.
Btw wrx3r, you actually got the passenger's side bracket to line up?!?!?!
Old 08-23-2007, 09:31 PM   #11 (permalink)
HUMANPIE's Avatar
That's nice. I'm jealous.
Old 08-24-2007, 02:31 AM   #12 (permalink)
wrx3r's Avatar
i made one so it would fit...no way in HELL i could get the other one to fit. but i figured regardless atleast the driver one did (in the pic its not lined up but thats because it was right after the install of the new bracket for the pass side)
Old 08-25-2007, 12:30 AM   #13 (permalink)
Club Region: NorCal
how did you make one?
Old 08-25-2007, 12:33 AM   #14 (permalink)
wrx3r's Avatar
^ took some sturdy metal from my grandpas shop and heated it up and bent it into the shape i needed
Old 08-25-2007, 12:00 PM   #15 (permalink)
Club Region: SoCal
Trader Rating: (1)
ok, that's what I thought.
