Old 06-20-2004, 02:32 PM   #1 (permalink)
Reputation: WRX_Stud is an unknown
Dsbc
ok so im thinking of getting a DSBC (dual stage boost controler) and i was wondering where you think would be the best spot to connect the 12v ignition on wire too ? thanks for the help guys!
Old 06-20-2004, 11:44 PM   #2 (permalink)
rex-ya's Avatar
Reputation: rex-ya is more helpful than not
if you haven't bought it yet. save your money and buy a UTEC. a boost controler is a waste of time and money. plus you'll be seriously leaning your car out. save yourself a lot of headaches and do it right the first time.
'06 WRX STi
Old 06-20-2004, 11:47 PM   #3 (permalink)
IBAUCLAPlaya's Avatar
Car: 04 WRX
Trader Rating: (1)
YOu want a UTEC
Old 06-21-2004, 01:14 PM   #4 (permalink)
i already have the Utec on my car, and the TXS turbo back exhaust .. including catless up and race downpipe .. so my next major addition is to go with a bigger turbo, and then FMIC ... but while i have almost all my gauges connected ... i figure ill run my wires for a DSBC if i decide to go that route .. unless you guys have a better thing to go to ??
Old 06-21-2004, 01:15 PM   #5 (permalink)
oh would my stock fuel pump and injectors handle a bigger turbo ? having thought of this .. maybe fuel system should be my next majour upgrade ?
Old 06-21-2004, 02:34 PM   #6 (permalink)
WRX_2NR's Avatar
Car: 04 WRX
Reputation: WRX_2NR is an unknown
The Utec has boost control option
I'm not totally familar with the Utec but I bet there is an input switch to switch to change boost maps like a dual stage boost controller acts
If you have a bigger turbo your definately going to need fuel pump and injectors
Old 06-21-2004, 03:39 PM   #7 (permalink)
Car: 04 WRX
Trader Rating: (1)
Don't waste your money on a boost controller if you have a UTEC. If you want to raise/lower boost a bit, use the ABC that is supplied w/ the UTEC.
