DP w/cat and o2 CEL fix - Subaru WRX Forum
post #1 of 8 Old 02-07-2005, 11:03 PM Thread Starter
janes5150 is an unknown
ok,im helping my buddy with his rex(and learnig alot about the car before i get mine)we both happen to have jobs that sorta "require"us to at least have one cat.so i figure that a cat in the DP as long as it is HI-FLOW will work for us.so who makes a good catted down pipe(that will bolt to a helix cat back)?and as far as i understand you put the 02 sensor back in but install the CEL in the wiring for the 02?i hope i got this right.he has a helix UP that we went ahead and installed the EGT sensor back in the pipe,until it goes bad.he carries the resistor just in case.thanks for all the help
janes5150 is offline
post #2 of 8 Old 02-08-2005, 02:36 AM
WRXtreme's Avatar
Helix actually makes a catted downpipe. That would be my suggestion, they seem to make very good products.
WRXtreme is offline
post #3 of 8 Old 02-08-2005, 09:49 AM Thread Starter
is it a hi-flow cat?
post #4 of 8 Old 02-08-2005, 09:52 AM
Cosmo's Avatar
Images: 15
All catted aftermarket downpipes use a high flow cat. At least, all of them I've ever seen...
Cosmo is offline
post #5 of 8 Old 02-08-2005, 02:13 PM
ac2600's Avatar
ac2600 is an unknown
cobb's DP with high flow cat is awesome, plus the high flow cat in it is near the "mid-pipe" section where the second stock cat would be. with the helix DP the high flow cat is right near the turbo. i dont know if that would actually cause any issues, but i'd rather have my cat lower in the DP rather than right after the turbo, plus cobb makes really nice stuff, its just more pricey. but i have a helix up-pipe and it works great so if youre on a budget, im sure it'd be fine.
ac2600 is offline
post #6 of 8 Old 02-08-2005, 02:36 PM
WRXtreme's Avatar
Cats work better better when they are hot so having them closer to the turbo is an advantage. Also, cats placed farther away from the turbo will give a better chance that the CEL will come on.
Props to Nick Warne for that info.....
WRXtreme is offline
post #7 of 8 Old 02-08-2005, 11:25 PM Thread Starter
OK,SO THAT IS COVERED
what about the install of the CEL fix.am i right in thinking that it has to be hard wired to the stock wiring harness?if i do that,then do i just screw the o2 back in and alls good??
post #8 of 8 Old 02-09-2005, 03:57 AM
liquidpopp3r's Avatar
liquidpopp3r is an unknown
Send a message via AIM to liquidpopp3r
the helix dp with cat warms up fast plus its near the turbo so yeah good on that... as for the cel fix hold off until you need it...just put the pipe on and slowly break it in like in my post called "cel?"...dont just romp on it...it worked for me
liquidpopp3r is offline
