dp install problem - Subaru WRX Forum
post #1 of 12 Old 09-25-2005, 10:54 AM Thread Starter
gingertooth is an unknown
dp install problem
just did up and dp install and now i am getting alot of noise behind the firewall inside the car. sounds like back pressure. i put a invidia dp to my stock catback and it is way loud now. and my dp was a little shorter than the stock one so now it pulls the whole catback up towards the front and the muffler hits the sway bar now too. can somebody tell me why i get the noise and what i can do about the dp being short. I get alot of vibration in the car where the new dp is.
gingertooth is offline
post #2 of 12 Old 09-25-2005, 12:03 PM
9d2TSi's Avatar
When I installed my dp on my car I got alot more noise as well, I'm assuming that it's from not being catted. As for the vibration and what not, I would say to go through and see if you can't reposition it somehow with all of the nuts/bolts loose and then retighten everything. When I did my exhaust, this is what I had to do.
Unforunately, the only real fix is going to be getting a catback as well. Then you shouldn't have any more fitment problems.
9d2TSi is offline
post #3 of 12 Old 09-25-2005, 02:28 PM
Jave's Avatar
Jave is more helpful than not
what does backpressure sound like?
I know after I installed my catless DP I had a whistling from the turbo that was alot more noticable.
▼SbiΣ Mi▼
Jave is offline
post #4 of 12 Old 09-29-2005, 12:44 PM Thread Starter
i found my dp hitting the cross brace on the frame underneath. it was making alot of noise though the whole car. i moved the dp a little and it is fine for now, but i have to go back and grind away some of the cross brace. it is too close. the dp was also an inch shorter and when i bolted it back up to my catback it pulled the catback and now my muffler hits my sway bar mount and rattles all day long. need to get my catback soon.
post #5 of 12 Old 09-29-2005, 03:56 PM
Images: 13
socal2fast4u is an unknown
What type of DP is it? My Helix mounted right up to the stock catback with no problems or noise or rubbing. I do get a loud whisle from the bellmouth but no other noise just a subtle deeper note to the exhaust but not much.
socal2fast4u is offline
post #6 of 12 Old 09-29-2005, 04:10 PM
Images: 13
Oops, Invidia OK. I swear I can read.
post #7 of 12 Old 09-29-2005, 11:00 PM
suddenthomas's Avatar
suddenthomas is more helpful than not
just out of curiousity could it be your waste gate whoosh that you are all noticing because now it can breathe as well I am not sure but just a suggestion
suddenthomas is offline
post #8 of 12 Old 09-30-2005, 08:11 AM Thread Starter
definately hitting cross brace. i moved the dp a little but it worked it's way back again. and my muffler rattles too since it hits the sway bar mount now. i just hope my new catback doesn't do the same thing.
post #9 of 12 Old 10-24-2005, 06:28 PM
jdmjones's Avatar
jdmjones is an unknown
my HKS DP came no where close to matching up with my stock exhaust.
jdmjones is offline
post #10 of 12 Old 10-24-2005, 08:54 PM Thread Starter
yeah mine either. right where the flanges meet. what piece of crap subaru flanges are. mine leak withmy stock catback but I am getting my catback soon. so screw it.
post #11 of 12 Old 10-25-2005, 01:35 PM
DEMENTED's Avatar
DEMENTED is an unknown
wow, that sucks. fitments issues are common with downpipes... but i hear nothing but good things about helix.
DEMENTED is offline
post #12 of 12 Old 10-25-2005, 01:41 PM
GetUpInDer's Avatar
GetUpInDer is an unknown
ALOT more noticable....
GetUpInDer is offline
