Hey, i have an 05 WRX with a Cobb AP, i just ordered my downpipe (Megan, catless) and i was looking through the search on here and online and i was looking at installation instructions and i was wondering do i even need to touch the EGT sensor? or do i have to unplug it? I know the AP takes care of the codes and what not but i'm just wondering do i need to even touch that sensor.
Is the EGT sensor on the Downpipe? If yes, then obviously you need to unplug and then replug into new downpipe. If it is not; then I have no clue; wait for someone who knows.
PS- Enjoy your Stage2 power when you get it installed. !Thumbs Up
if it's the downpipe then it is a 02 sensor and yes just unplug it and take it out of the downpipe and reinstall it into the new one. also for those who don't have a ap you can drill out a spark plug defouler and use that as a cheater. i did it and it works great.
I could not remember so I looked at an exhaust chart and the EGT is in the up pipe. Some down pipes have an additional port for tuning (such as the cobb). There is a second o2 sensor in the down pipe that may or may not have a port in the new pipe.
Yes you have a sensor that you will have to remove. You will need a 7/8 open wrench that you can borrow from autozone. spray some liquid wrench on there first...in fact spray that shit on all those bolts you will need to take off, it will make your life easier. And that intercooler can be a bitch to put back on, use some spit to lube it up or heat it up with a hair dryer.
Ya, your right the EGT is in the Up-pipe so i'll have to take it off to get the Up-pipe off, i'm looking at up-pipes now and i figure i might as well get one while i'm down in that area replacing the downpipe, do Up-pipes all have ports to plug the EGT back in or do you just leave it hanging if it doesn't, sorry if that doesn't make sense, freakin sensors are confusing me.
my cobb up has a egt bung, but i plugged it with a M12x1.25 bolt, and installed a 2.2k ohm 1/2 watt resistor in the plug that the egt plugged into ( the end that goes to the ecu). I havent had one problem with it in over 4 years.
you want to replace that up-pipe anyway when doing a downpipe, with that extra flow you can suck that cat in your up-pipe into your turbo which obviously would be very bad.
What? I read somewhere that stock WRX turbos love eating uppipe cats for lunch....
/sarcasm
That's the way I see it, you might as well save you the future trouble and get an uppipe too; Invidia makes a good one for the price; HKS' is decently priced I think, and plenty others like DC Sports, Megan racing, etc.
Nagyhead: you only have to do that though if you have no EM right? Cause I have the Cobb AP, so i can just plug the EGT back in and not worry about anything?
x2. Ebay is good for certain things, but not so much on others... Get something good name brand like COBB, Invidia, etc.
hey I have a random question. Will an OEM uppipe from an 06-07 WRX fit on an 02-04 WRX? because they come catless on the 06-07 right? So if it would fit; you could just buy the stock one off of someone. I think i've asked this question before; but I cant remember the answer. :yawn:
Yeah true. But if you just happen to find one out there; i'm sure you could get a decent price on it. But I wouldn't sit there waiting 5 years just to get one lol
