downpipe install - Subaru WRX Forum
post #1 of 8 Old 07-21-2005, 04:59 PM Thread Starter
BangWRX's Avatar
BangWRX is an unknown
downpipe install
would it be better to back my car up on rhino ramps or use jacks?
BangWRX is offline
post #2 of 8 Old 07-21-2005, 05:07 PM
scoobnoob is an unknown
im not sure which is better but wouldnt you want the front end on rhino ramps instead of backing it up cause the downpipe is in the front of the car. anyways if it was me i would use jacks.
scoobnoob is offline
post #3 of 8 Old 07-21-2005, 05:10 PM
Jave's Avatar
Jave is more helpful than not
I used ramps on the front and jack stands on the back. of course I was doing a TBE all at the same time.
Jave is offline
post #4 of 8 Old 07-21-2005, 05:13 PM Thread Starter
BangWRX's Avatar
well i am doing the entire turbo back all at the same time. I was planning on just having the backend elevated because i figured if i have the frontend elevated than i might not have enough room to get to my downpipe, heatshield etc. Wouldnt it be easier if the front was lower to the ground?
BangWRX is offline
post #5 of 8 Old 07-21-2005, 06:48 PM
Jave's Avatar
dont know, we replaced my Uppipe at the same time so we had to have the front up in the air. We just left it there until we were done. It wasnt to difficult with it up.
Jave is offline
post #6 of 8 Old 07-21-2005, 06:56 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
You will be better of with the jack stand in the front because you will have to be able to access the DP from the top and the bottom, so you might have to lift and lower it a few times. Ramp the rear
Ian is offline
post #7 of 8 Old 07-21-2005, 07:30 PM Thread Starter
BangWRX's Avatar
yeah thats what i was thinking... thanks
BangWRX is offline
post #8 of 8 Old 07-21-2005, 08:30 PM
WRXtreme's Avatar
All i used was 2 stands on the front for my TBE. The backend was sitting on the ground and I had no issues.
WRXtreme is offline
