-   -   Downpipe cat gut help (http://www.wrxtuners.com/forums/f52/downpipe-cat-gut-help-34297/)
DaveC03wrx 04-20-2013 08:27 PM
So i bought a used helix catted dp and the cat was bad in it. Im trying to gut it but the cat is right after the belmouth opening. If i dont get it completely gutted will it cause problems? Aaand any suggestions on a more efficient way of gutting the cat than a bent 12" screw driver and a hammer?
pzr2874 04-20-2013 11:22 PM
Drill and a spade bit.
Electric if feasible.
DaveC03wrx 04-21-2013 05:03 AM
My only problem is the cat is located after the bellmouth bends so itd hard to get anything down there
boo-key 04-21-2013 05:27 AM
549 Attachment(s)
cut, gut, and reweld.
the RIOT act 04-21-2013 08:44 AM
[quote=boo-key bear;297809]cut, gut, and reweld.[/quote]
Frankenstein! FOL
DaveC03wrx 04-21-2013 11:46 AM
Cut gut reweld would be mint if i had a welder.. think i might just go buy a small drill and a long bit
boo-key 04-21-2013 12:33 PM
549 Attachment(s)
Muffler shop might be able to weld it back for you for a reasonable price. Probably would be cheaper or about the same as the bit will cost. Either way will work though. Whatever gets you the results your looking for. Just curious, how do you know the cat is bad?
DaveC03wrx 04-21-2013 01:15 PM
I could hear the cat bouncing around in it. I shoulda just put it on and drove it like that for a while. But a guy at the muffler shop stuck a camera down the pipe and found some debris n cracks. Soo im trying to gut it. Bout to go buy some rebar. From what ive been reading its not too big of a deal if the cat starts to fall apart in the dp. As long as its after tho motor. Hopefully it doesnt get sucked backwards somehow
06_hawk_eye 04-21-2013 03:13 PM
My helix catted downpipe sounded the same way bought it used and it would rattle in side of it as well. Threw it on the car anyway and doesn't make any sound. Think that's how it's suppose to be and when it heats up it expands to the pipe.
DaveC03wrx 04-21-2013 04:08 PM
Then i started gutting it for no reason lol shitttttt. Will anything bad happen if input it on now
06_hawk_eye 04-21-2013 04:33 PM
Depends on how far you got into gutting the downpipe?
boo-key 04-21-2013 04:37 PM
549 Attachment(s)
I wouldnt think so unless the flow reversed somehow. If you are gonna quit gutting it just blow it out really good with a air compressor before you reinstall but, you have gone this far. Might as well commit now.
06_hawk_eye 04-21-2013 04:40 PM
Yeah if you started the gutting mine as well go forward and finish it. Good luck man
DaveC03wrx 04-21-2013 05:24 PM
1 Attachment(s)
Thats how much ive gotten so far. I think ill blow it out with my power washer then put it on and see what happens. I just read that alot of people drill holes in clogged cats. Its just scary since its right after the belmouth curves down
mosc 04-22-2013 08:24 AM
Dude, be careful. The fumes that come off of it when you drill into that cat are incredibly toxic.
