do u have to worry about running lean when u.....? - Subaru WRX Forum
post #1 of 11 Old 03-11-2003, 05:58 PM Thread Starter
duba-u-R-x is an unknown
just have k@n, down pipe, up pipe, and full exaust at stock boost levels?? also with just these mods do u have to worry about fuel cut??
duba-u-R-x is offline
post #2 of 11 Old 03-12-2003, 07:10 PM
koki is an unknown
i have the same set up but mine is turbo xs and the drop in filter is green, do you have a boost gauge? i dont worry about that fuel cut off its arround 17.5 psi of boost i only do 14 psi of boost so im safe ,what times you put on the 1/4 mile and speed?
koki is offline
post #3 of 11 Old 03-13-2003, 04:01 PM
WhatleyWRX is an unknown
You should probably be safe. However, when my roomate had the same stuff he was experiencing boost creep. Impressive amounts of it as well, I witnessed his Greddy Boost Gauge read 1.4 Bar. Thats spooky and could introduce quite the lean condition.
Watch your boost guage if you got it, and don't do the 3/16" restrictor mod and you'll probably be fine.
Whatley.
WhatleyWRX is offline
post #4 of 11 Old 03-13-2003, 04:58 PM
IMPREZvWRX is an unknown
Send a message via AIM to IMPREZvWRX
Whatley.
The spiking might be caused by a downpipe that has no provisions for the wastegate. If it's blocked off by a bad downpipe design, it can't work properly.
Chris
IMPREZvWRX is offline
post #5 of 11 Old 03-13-2003, 06:47 PM
Suspended
conejo is an unknown
Send a message via AIM to conejo
Im wondering if I istall a cold air intake in my stock wrx will i run leaner?how about with cat-back exhaust?
conejo is offline
post #6 of 11 Old 03-13-2003, 06:51 PM
You will run leaner with the CAI, probably not with a catback.
Whatley.
post #7 of 11 Old 03-13-2003, 08:36 PM
koki is an unknown
hey i have the 3/16 mod and the turboxs complete and i have seen spikes to 14 go down then back to 14 sudently and then doit again the it holds for a bit at 14 then drops to 10 in 4 gear wthfck?its very fast not even a sec. drops then climbs again to 14
koki is offline
post #8 of 11 Old 03-14-2003, 09:16 AM Thread Starter
whats the 3/16 mod?
post #9 of 11 Old 03-14-2003, 11:34 AM
The 3/16" mod is replacing a inline restrictor in the boost control line. The stock one is something like 1/8" so people would replace this one with like a brass 3/16" one from Home Depot. Basically, the restrictor is there to smooth out the signal to the wastegate actuator. At work we use needle valve to speed up or slow down control valve response, which is the same thing Subaru is doing with this restrictor.
By adding this people could get higher boost without anything else, of course the boost is mostly from spiking, caused by the wastegate overcompensating. My roommate bought me one, and its still in the plastic baggy in the top of my toolbox. I'd never put something like that on my car
Cheap doesn't always mean better.
Whatley.
post #10 of 11 Old 03-16-2003, 11:15 AM
koki is an unknown
on my car has never passed from 14 psi boost still im in a safe spot
koki is offline
post #11 of 11 Old 03-17-2003, 12:26 AM
Suspended
WHAT CAN I DO SO I DONT RUN LEANER WITH THE CAI?
conejo is offline
