cutting out problem please help - Subaru WRX Forum
post #1 of 24 Old 12-08-2008, 04:07 PM Thread Starter
squirells 06's Avatar
2002 wrx,TBE, catted UP,Cobb ap currently off but it was doing it while it was on also.
ok here it goes, when ever i am in 2nd,3rd,4th or 5th and im just cruisein at like 3k rpm's and i lay it to the wood ,as it is boostinand at high rpm's it starts cutting out almost like when you run out of gas and sometimes its throws the CEL and says misfire in cyl 3. i have already swapped the coils. does anyone know what this could be, injector, fuel filter, fuel pump, fuel rail ............ anything/anyone. oh what is the restrictor pill thing everyone is talking about.
thanks for any help
justin
squirells 06 is offline
post #2 of 24 Old 12-08-2008, 05:43 PM
The restrictor pill or "orfice" as subaru calls it is used to regulate the air flow to your wastegate from your turbo compressor housing. If you are hitting your normal boost it wouldn't be a matter of the restrictor pill...
TurboRyan is offline
post #3 of 24 Old 12-08-2008, 05:43 PM
03 CrazyTaxi's Avatar
Sounds like fuel cut. Either that or you just aren't getting enough fuel to the engine. Start by checking fuel filter, after that you may want to let us know what boost you're running. It could be that you are hitting boost cut instead. If that's the case, tuning is in order.
03 CrazyTaxi is offline
post #4 of 24 Old 12-08-2008, 06:11 PM Thread Starter
it starts doin ti even before the turbo starts boostin, but if it was the fuel filter would that make it throw the CEL.???
post #5 of 24 Old 12-08-2008, 06:13 PM Thread Starter
off subject,\
hey turboryan how much about are you puttin to the wheels?
post #6 of 24 Old 12-08-2008, 06:57 PM
Not sure... I haven't had it on a dyno yet. The map says 337hp, but i doubt its to the wheels...
By the way i put in a new fuel filter on sunday, i could feel a big difference in acceleration.
post #7 of 24 Old 12-08-2008, 08:22 PM
Well, #3 is the furthest from the filter. If it's clogged, you might have a drop in pressure causing less fuel to get to the cylinder. Now, this is speculation but it seems to make sense in my head...
post #8 of 24 Old 12-08-2008, 09:13 PM Thread Starter
ok well i will try the filter this weekend and get back to you guys and let you know.
thanks for the input
post #9 of 24 Old 12-10-2008, 06:11 PM Thread Starter
where is the fuel filter. havent even looked for it yet
post #10 of 24 Old 12-10-2008, 06:23 PM
I followed these instructions:
FUEL PUMP INSTALL
post #11 of 24 Old 12-11-2008, 05:46 PM Thread Starter
yea is was not either fuel filter , any other suggestions. it only cuts out when when it is in gear under load. i can rev it neutral and it is just fine. what next feul pump? and could it possably be the ECU? god i hope not
post #12 of 24 Old 12-13-2008, 12:49 PM Thread Starter
ok i just got all new coils and had the injector's pressure tested and cleaned and now it is doin it worse than ever. im not talking just a little bit, im talking the entire time i am accelerating no matter how light i am on the pedal and now it is throwin: cyl 3 misfire and cyl 2 misfire and another code that just says PFFFF? have no i dea what that one is. i reallly really need help this is my only transportation to get to SCHOOL and WORK. so any other suggestions anyone. thanks Turboryan and Crazytaxi for you help.
post #13 of 24 Old 12-13-2008, 02:04 PM
Have you replaced the FP? Your FP could be going bad.
Kjott21 is offline
post #14 of 24 Old 12-13-2008, 02:29 PM Thread Starter
no sir not yet im going to do that monday hope thats it thanks.
post #15 of 24 Old 12-14-2008, 12:20 PM
Thats just about the last thing beyond spark plugs...try the FP. If nothing else works take it to a dealership or a mechanic. Because their is something definatly wrong.
