Ok,
What does everybody think... i've been researching for an intercooler sprayer for my Hyperflow top mount intercooler used in TXS stage 3.
First desire was a nice manual water sprayer kit. I've been looking around and DEI appears to trump the water sprayer with a Cryogenic style intercooler mister.
www.designengineering.com
Uses a bottle of liquid CO2 (mounted much like bottle of NOS in your trunk) to mist a subzero temperature CO2 gas right onto the intercooler. Thus accomplishing a much more effective cooling of charged air than the water sprayer can... I'm all about this item and going to order it today. They will be making me a special (flat version) of the sprayer with the hose and solenoid connected flat to the sprayer bar (for clearance of the hood) for $380 (includes install kit, 10lb bottle, mister, and solenoid)... I'm psyhed to get this installed and try it out... mister is 16x5 so it should be a nice fit on top of the 19x7 intercooler surface.
I have already spoken with Phil at TurboXS, he feels it will be a worthwhile addition and suggests there should be no problem with running same boost of 17 psi and fuel timing in stage 3. Can even be setup to run with the solenoid driver on the UTEC, or just use the manual push button that the system comes with. The added cooling (or should i say "freezing") should create a denser air charge, effectively increasing horsepower and decreasing exhaust gas temps...
Can have the bottle filled any place that re-fills CO2, as used in paint pellet guns and so forth.
