» Sponsor Links
»Garage Storage and Cabinets
Old 12-31-1969, 07:00 PM   #1 (permalink)
phast's Avatar
Reputation: phast is an unknown
Send a message via AIM to phast
Never thought about that. However, I see one problem with that. If you are talking about mounting an airbox directly under the hood scoop, it seems that things would get pretty wet and dirty. I'm not sure what they did to take car of this with the 2.5RS intakes.
Most of the 2.5RS intakes that I have seen have a mandrel bent pipe coming from the throttle body and loop around to mount the cone filter somewhere in the vicinity of where the stock box is on the WRX.
It would be a nice source of cold air, not to mention really cool when you pop the hood. You would need to relocate the hotwire MAF sensor and form some toubing to the compressor inlet.
-jay
02 wrx wagon
VF30 and NAWZ powah!
Old 12-31-1969, 07:00 PM   #2 (permalink)
Reputation: nekard is an unknown
Send a message via AIM to nekard
Good point phast. You could go to a front mount intercooler but if you arent running well over 300 HP I dont think that you could utilize it. Besides who would want to give up those gorgous fog lights?! :P
2002 Silver WRX
Link Programmable ECU, TurboXS Stainless Steel Turbo-back exhaust, TurboXS BOV Type H, Black Samco Intercooler Hoses, 17x7.5" Rota Steel Grey Subzeros with Kumho Esta 235/45/R17 tiresPioneer Dehp9300
Old 12-31-1969, 07:00 PM   #3 (permalink)
Reputation: CTRallyRacer is an unknown
So, to install a front mounted intercooler... I have to remove the foglights?
Old 12-31-1969, 07:00 PM   #4 (permalink)
Yes. You also have to cut pieces of the sub frame out that the bumber covers. I was in the same boat as you when I first started looking at front mount intercoolers. I found that you had to delete the fog lights and do a lot of cutting. Its your call but you can try.
2002 Silver WRX
Old 12-31-1969, 07:00 PM   #5 (permalink)
phast's Avatar
The APS fmic from Cobb doesn't require the extensive hacking that the Blitz kit does. However, you still lose the fog lights.
-jay
02 wrx wagon
Old 12-31-1969, 07:00 PM   #6 (permalink)
That is very true. But who would want to get rid of those beautiful fog lights?! :P
2002 Silver WRX
Old 12-31-1969, 07:00 PM   #7 (permalink)
Is there a specific reason why the piping is at the bottom of the intercooler? Could it be at the top? If it were at the top.. then you coud possibly keep the fog lights... or a different set anyways...
Old 12-31-1969, 07:00 PM   #8 (permalink)
The pipping is at the bottom because that is the easiest way to route all of the pipping that is needed to get the cold air to the intake. Yeah You could reroute it to be right in front of the radiator but then what would you do about the cooling of the engine?
2002 Silver WRX
Old 12-31-1969, 07:00 PM   #9 (permalink)
Hrrmmm... I'm going to keep looking for a FMic that won't remove anything.. once I get all the information solved for my LCD gauges that I'm looking for...
Old 12-31-1969, 07:00 PM   #10 (permalink)
Well hell keep looking for both. Dont worry either because as soon as I find a FMC that doesnt delete anything I will be posting it something mad!
2002 Silver WRX
Old 12-31-1969, 07:00 PM   #11 (permalink)
Reputation: Shawn is an unknown
I've read of a lot of folks moving the IC to the Airdam and then using the Scoop for venting the engine compartment by using the STI hood cutout's. The Rex's engine compartment gets SMOKIN hot and it can't do anything but help.
Shawn
Old 12-31-1969, 07:00 PM   #12 (permalink)
But if you move the IC to the front of the car you loose the fog lights, correct? I just cant give em up!
2002 Silver WRX
Old 12-31-1969, 07:00 PM   #13 (permalink)
Cold air intake in place of intercooler?
Back on the 2.5RS, there were kits to make the hood scoop functional with a cold air intake. I was wondering if it was possible to go to a front mount intercooler and then go to a top mount cold air intake? I like this idea better than sticking the instake into a wheel well.... could be a dirty prospect in rain, dirt, muddy conditions...
