Cobb intake for a stock wrx? - Subaru WRX Forum
post #1 of 14 Old 09-21-2006, 11:04 AM Thread Starter
Strider327's Avatar
Is this safe to install? Will it hurt the car in anyway? I've done my research on intakes, I'm just looking to see for reliability. And how I ended up with a Cobb intake is a LONG story it wasn't by choice it was actually a mistake in a way. But in any case I just want to make sure that I can use it without an engine management system. Thanks.
I have a 04 WRX Bone stock.
Strider327 is offline
post #2 of 14 Old 09-21-2006, 11:27 AM
need2boost's Avatar
Yes the cobb intake is the only intake designed to adjust the flow of air into the MAF so it can get an accurate reading, the difference is in the pipe, if you get a chance to look at it you can see the difference, won't see much performance increase, but i bought mine for the great spooling sound and BOV sound. I know I'm a ricer lol, J/K. you won't need E/m for just a Cobb intake, beware of other intakes esp. cheaper ones.
need2boost is offline
post #3 of 14 Old 09-21-2006, 11:40 AM
With 54 posts you would think you would have taken a gander at the stickies or worked the search feature a couple of times.
dumdum is offline
post #4 of 14 Old 09-21-2006, 12:08 PM
9d2TSi's Avatar
You can use it, but without a way to see what your AFR's are, it's going to be a crap shoot.
9d2TSi is offline
post #5 of 14 Old 09-21-2006, 12:15 PM
trek98xc's Avatar
Send a message via AIM to trek98xc
The Cobb and SPT intakes are the only ones you can run without getting a tune.
rob
▼SbiΣ Mi▼
trek98xc is offline
post #6 of 14 Old 09-21-2006, 12:47 PM
The K&N,APS,TurboXS and Perrin short rams also retain the stockbox I.D. (65mm) along with apropriate MAF alignmet.
http://www.perrinperformance.com/pro...ake_system.htm
http://www.airpowersystems.com.au/wr...leaner/pod.htm
http://www.pdxtuning.com/store/showp...&categoryid=15
dumdum is offline
post #7 of 14 Old 09-21-2006, 12:58 PM Thread Starter
Strider327's Avatar
Thanks to all of you. The reason why I bought one for 10 bucks!!!!! Believe it or not, and because one my stock air filter was damaged (ripped) and second I needed to get another filter anyway but it was gonna be around at lest 30 bucks....so I saw this on craigslist and was like what the hell mine as well right. But I'm glad I can use it without any problems. Thanks again.
post #8 of 14 Old 09-21-2006, 01:09 PM
Is it one of the older 2 piece metal SF intakes?The had a problem with the silver ones coming apart.
http://forums.nasioc.com/forums/showthread.php?t=994216
Hang on to your stock box or what ever you were using prior just incase.I'm sure if it does you can send it back to Cobb to replace it.
dumdum is offline
post #9 of 14 Old 09-21-2006, 01:11 PM
Chris Rx's Avatar
cobb and spt , only intakes worth buying without tune, im running cobb SF and love it.
the first gen cobb SF is aluminum and falls apart, i tig welded it back together so its perfect now, but the new cobb SF i heard is a hard plastic, and doesnt fall apart. either way, make sure you have a heatshield when using either
Chris Rx is offline
post #10 of 14 Old 09-21-2006, 01:14 PM Thread Starter
Strider327's Avatar
Its the hard plastic black one. So I think its the second version. Thanks.
post #11 of 14 Old 09-21-2006, 11:53 PM Thread Starter
Strider327's Avatar
Which heatshield are you referring to Chris? Do you have a link to one? Let me know, thanks.
post #12 of 14 Old 09-22-2006, 07:13 AM
Its the SPT one.It's an option and does not automaticly come with the intake.
dumdum is offline
post #13 of 14 Old 09-22-2006, 07:17 AM
9d2TSi's Avatar
If all else fails, you could fab up your own heatshield. I would try that since you got the intake for so cheap. Good score there, btw.
9d2TSi is offline
post #14 of 14 Old 09-22-2006, 09:21 AM Thread Starter
Strider327's Avatar
Thanks, I'll look into to it. And yeah it was big surprise! At first I was like it can't be true. A Cobb intake especially Cobb for $10? What's wrong with this picture but it turned out to be real and works well, I'm happy.
