Can I do this? - Subaru WRX Forum
post #1 of 5 Old 06-29-2006, 01:02 PM Thread Starter
niceguy is an unknown
Can I do this?
I have searched and I am aware of the OL/CL and the difference between the newage and the classic ECU.
But, I would still like to ask if I can put the following onto my 05 WRX 8 and drive without a remap?
Divorce decat Downpipe
### Sti catless Centre Section
Sti Back box
K&N Panel filter
Will I get any CEL warning lights or risk the Up pipe cat giving up thus damage my turbo with only a turbo back exhaust?
There is only one registered Ecutek mapper here and the cost is around 950 usd. Should I go ahead with their remap (only road tune, no dyno)?
niceguy is offline
post #2 of 5 Old 06-29-2006, 02:31 PM
theaxemaster is an unknown
I don't know what the "Sti Back box" is, but the rest of that will run fine without any sort of remap. And unless you're getting the Bosal 2 piece-type DP, you shouldn't need a catless center section with a catless DP. The DP should cover both the downpipe and the midpipe.
You WILL get a CEL though, and I would certainly get a UP before doing the job. May as well take out ALL the restriction while you're doing it. Save the 900, get a UP and either a Cobb AP or a TurboXS UTEC, then you can just run the stage 2 map.
theaxemaster is offline
post #3 of 5 Old 06-29-2006, 09:03 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Yes you can run that setup, Yes you might get a CEL and I would get the up pipe before tuning. Go for the Ecutek, it will be fine with just a road tune
Ian is offline
post #4 of 5 Old 07-13-2006, 04:39 PM
LilSix's Avatar
LilSix is an unknown
950 for a road tune, thats crazy. Get a Cobb Accessport. Save your self 350-400. Plus you can do it yourself.
LilSix is offline
post #5 of 5 Old 07-24-2006, 09:38 PM
hondaeater is more helpful than not
the ol/cl issue is real and documented. If you don't have the means to monitor knock activity via knock correction values and the DAM (dynamic advance multiplier) than i recommend you get proper engine management when modding your exhaust.
hondaeater is offline
