BOV Issue - Subaru WRX Forum
post #1 of 16 Old 04-11-2011, 11:02 PM Thread Starter
04psmwrx is an unknown
BOV Issue
hey guys im new to the subaru world but im not new to bovs and aftermartket parts. I bought an 04 wrx completely stock with 135000 miles on it. the ca had a blown head gasket and blown turbo I ended up buy the car for a little over $4,000. I ended up having a brand new ej205 motor put in. everything is brand new turbo seals everything. I bough a hks bov limited edition and put it on. I got the Flange that bolts up to the tmic. after i installed you i started noticing some weir things. my car was idleing crappy and you can't hear the bov unless your above 7k rpms and even then its super quite. my question is do i need a cobb ap to tune it or am I missing a gasket some where? I'm also wanting to do a hks carbon ti catback would I need the AP for that?
here is a little history of my car background.
my first car was a 1997 Mitsubishi Eclipse GSX i bought the car stock in 2008 from a 60 year old man with 50,000 miles on it. when I got the car I put on a huge FMIC custom turbo back exhaust a greddy rs bov and an hks intake. not long after that i upgraded the turbo i put on a evo iii and walbro fuel pump. in the summer of 2010 i decided it was time to reallt get serious with the car so i had a full motor built and everything upgraded ill put the list of everything below
6 bolt swap
Manley Platinum Pistons
Manley "Turbo Tuff" I-beams
ARP 2000 Rod Bolts
ACL Tri-Metal Race Main & Rod Bearings
ATI Super Harmonic Damper
.5mm Oversized Stainless Valves
Manley Valve Springs
Manley Titanium Retainers
Manley Valve Locks
ARP Head Studs
Mitsu MLS Headgasket
Brian Crower Stage 3 280* Cams
Unorthodox Cam Gears
Unorthodox Underdrive Pulley Set
Prothane Motor Mounts
Taylor 10.44mm Plug Wires
BR8ES Plugs
Forced Performance 3065 Turbo
Tial 44mm External Wastegate
Tial 50mm Blow Off Valve
Forced Performance Race Exhaust Manifold
Forced Performance SS o2 Housing
Apexi N1 3" Turbo-back Exhaust
SBR FMIC w/ 2.5" Piping
Hogan SMIM
Evolution 8 MAF
Forced Performance Intake Pipe
K&N Air Filter
Hallman Boost Controller
Fluidyne Radiator
Slimline Fans
ECM Link V3
GM 3.3 Bar MAP Sensor
AEM UEGO Wideband
FIC 1150cc Injectors
Walbro 255 intank pump
Walbro 255 inline pump
-6an SS Fuel Lines
Venom Hi Flow Fuel Rail
Fuel Pressure Regulator
TRE Stage 2 Performance Transmission
4 Spider Center Diff
ACT 2600 Clutch
ACT Streetlite Flywheel
3 Speed Scattershield
SS Clutch Line
Shifter Bushings
Tokico Illumina Shocks
Eibach Springs
Cross Drilled Rotors
SS Brake Lines
HKS Turbo Timer
Stewart Warner Boost Gauge
VDO Cockpit International Series Gauges
- Oil Pressure & Water Tempature
Greddy Counter Weight Shift Knob
sold 3/31/2011
04psmwrx is offline
post #2 of 16 Old 04-12-2011, 12:26 AM
Hondafan's Avatar
The car doesn't need a BOV on these and the cars don't generally run all that happily with them. Did you check to make sure the vacuum line to the smaller fitting is connected with no leaks? It sounds like the actuator vacuum line has a leak. Then make sure you have a plug in the recirc pipe. These cars will not work like a DSM if you don't cap that hose.
-Brad
Hondafan is offline
post #3 of 16 Old 04-12-2011, 08:26 AM Thread Starter
i have already capped the recirculation hose. and i used the adapter for the vacum that came with the bov kit.
04psmwrx is offline
post #4 of 16 Old 04-12-2011, 08:49 AM
bad grocerygetter's Avatar
You asked about having an ap but to answer your question...no you won't need one. If you are gonna run with a bov, you may need to adjust it. Im not all that familiar with them because i run the stock bypass valve. But i do know that some will need adjusting. oh and you may check at the bov flange to make sure you have a good seal there. Sorry i don't have any more info. Hope you get it fixed man! Good luck.
Ps. are you getting boost? If so do you have a boost gauge? If so what boost are you hitting?
Kevin.
bad grocerygetter is offline
post #5 of 16 Old 04-12-2011, 06:04 PM
I myself came from DSM. 10years of gst's tsi's gsx's. And Im gonna tell ya what you dont really want to hear. Get rid of the HKS SSQV!!!. your car does NOT like it!.
When I got my WRX just a few months ago I did the same exact thing even though I had read in the forums no to. I should have listened because that was just money wasted that I could have spent elsewhere. But what I did do there after was find a nice substitute, the TurboXS RFL. my car runs just fine with that. the thing with the SSQV is it doesn't hold a very good seal at all where the RFL does. So if you really do want a BOV than I will recommended that one...just make sure that your gasket at the tmic is in place and that the vacuum line is on tight, if its not snug it will also start to run shitty!!
You will hear time and time again that there is no need for a bov unless you have huge gains under you hood but I cant live without my PsssssHHHH!!!! And a lot of guys will tell you to put your stocker back on, but yet again, thats all in your personal taste. But I will suggest you do so until you have a diff BOV other than the SSQV, ### your just gonna stall out and look like a douche.haha.......GOOD LUCK...CHEERS
post #6 of 16 Old 04-12-2011, 06:44 PM
^^^ +1
Kevin.
post #7 of 16 Old 04-12-2011, 10:21 PM
Hondafan's Avatar
My '02 already had the RFL on it when I bought it, and it ran fine. I liked the whistle sound the HKS gave though, and I did that on my '08. I didn't have any idling problems, but every once in a while I'd get some popping from the exhaust. That did make me feel like a d bag, but not enough to make me uninstall it. The ex-wife also loved the sound and wanted me to get it. I haven't installed a BOV on my STi and I'm finding I actually can live without the sound.
-Brad
Hondafan is offline
post #8 of 16 Old 04-12-2011, 10:38 PM Thread Starter
hey guys thanks for the replies. i took my car in on saturday just have some stuff looked at casue i thought things were wrong turns out the the speed sensor and a few other sensors were bad. i had them all replaced and now everything is perfect. the car runs amazingly and the bov sounds amazing! (: what are you're guys take on a cat-back or turbo back. should i buy a AP or dont waste the money on it
04psmwrx is offline
post #9 of 16 Old 04-13-2011, 04:00 AM
your only going to get away with a cat-back without a tune. If you do turbo back then you will NEED one.
post #10 of 16 Old 04-13-2011, 07:35 AM
don't waste the money on an AP go opensource!
post #11 of 16 Old 04-13-2011, 07:54 AM
I run a Cobb ap and i love it. But it really depends on how far you wanna build your car. I would agree with Matt but only if you are gonna mod your car like you did with the dsm. If all you wanna do is exhaust and bov i would say accessport is a very cheap and easy option. Imho. I've just been running stage 2 ots map for about a month now and its a very nice upgrade and since i live 5 hours from the nearest awd dyno it was the easiest way for me. I will eventually be doing some fuel system upgrades and possibly an e85 tune. But like randy was saying...you can do the catback and be fine without a tune But if it were me I would spend an extra couple hundred and get a downpipe also. The Oem one is horrible it has a steel plate covering half of the turbo outlet. good luck with the car man.
Kevin.
post #12 of 16 Old 04-13-2011, 05:49 PM
Just don't run the OTS map for a long period of time Kevin. I mean like close to 2 years...it could come back to bite you in the ass. A protune is always better than a OTS map.
post #13 of 16 Old 04-13-2011, 07:30 PM
except an AP isn't exactly cheap, it's actually almost the cost of 2 pro-tunes which if you built the car past stg 2 you would need anyways so your up to the price of 3 tunes and you only get 2, not to mention most tuners charge more to do custom maps for the AP vs. opensource, and your car will run better and usually get better fuel economy with the OS tune because your tuned to your own specific climate and fuel
+1
post #14 of 16 Old 04-14-2011, 10:21 AM
Yeah i have been reading a lot about e85. I have a station down the street from my house that sells it. I want a protune so i figure ill just up my injectors size and slap in a walboro 255 and while Im at it just tune for it.. prob won't build this car much past that. Its getting a little old. Milage is getting up there
Kevin.
post #15 of 16 Old 04-14-2011, 07:46 PM
Hondafan's Avatar
My tuner doesn't charge extra to tune with the AP. I like having it with me to check on things and datalog. I guess it's more because I'm familiar with it because I've had an AP V2 on all 3 of my Subies. I like the "on-the-fly changes like launch control, flat foot shifting, and the monitoring capability without having to hook up a computer. I know I paid more than an OS tune, but I'm really happy with it as I'm not experiencing any downsides otherwise. I also like that my tuner will be making me a couple maps that I'll have saved on the AP so I can reflash while I fill up with E85 or 91. Just a couple things I like about it.
-Brad
Hondafan is offline
