BOV - Subaru WRX Forum
post #1 of 7 Old 12-31-1969, 07:00 PM Thread Starter
Send a message via AIM to STiWRX
They're pretty much just a noise mod.....In a way, they actually hinder performance....IF you get a 100% atmosphere dump, they actually cause some overfueling and make your car run rich when you let off the gas to shift. If you go this route, my best suggestion is to go with atleast a catless uppipe. The overfueling causes some backfiring and if this happens in the cat before the turbo, and the cat decides to self destruct, you will destroy your turbo's turbine blades....But that will take a long time, nothing that will happen overnight. I have the HKS SSQV BOV full atmosphere dump and I'll live with the little bit of backfiring when I shift, and the ECU eventually learns not to overfuel so much....So it works out....
Bill Janczewski
STiWRX is offline
post #2 of 7 Old 12-31-1969, 07:00 PM
Send a message via AIM to nekard
Interesting. My computer has yet to learn not to overfuel. Maybe that catless uppipe with cause it to quite. I feel like a redneck with a big shivy truck when it backfires into the cat.
2002 Silver WRX
Link Programmable ECU, TurboXS Stainless Steel Turbo-back exhaust, TurboXS BOV Type H, Black Samco Intercooler Hoses, 17x7.5" Rota Steel Grey Subzeros with Kumho Esta 235/45/R17 tiresPioneer Dehp9300
nekard is offline
post #3 of 7 Old 12-31-1969, 07:00 PM
Send a message via AIM to Lachlanus
What about a unichip? Can you "tell" the unichip you have a BOV so it can use it to better performance?
Lachlan
Lachlanus is offline
post #4 of 7 Old 12-31-1969, 07:00 PM
I guess what I'm saying is I want sound and performance too. Is that going to happen? Or is it just a pipe dream?
Lachlan
post #5 of 7 Old 12-31-1969, 07:00 PM
You will be getting one or the other...not both.
2002 Silver WRX
nekard is offline
post #6 of 7 Old 12-31-1969, 07:00 PM
Actually, from what I have read, the ideal BOV will split the blow off. Half to atmosphere and half to the recirculation. This helps prevent overfueling and helps keep the turbo spinning. The only one that I have seen like this is the GFB unit. Lowest price I have found is $185 @ http://www.subaruwrxparts.com/
radrex is offline
post #7 of 7 Old 12-31-1969, 07:00 PM
BOV
Does a BOV improve performance (eg spool up)? Or is it just for sound?
Lachlan
