hey im looking to get a low budget cat back for my 02, thinking about the borla 2.5 cat back. i dont want anything loud, just want a deep throaty sound, is it a good choice, or should i go w/ the sromung muffler?
I just purchased the Borla 3" for my 04 wrx. it is AMAZING. I love the deep throaty sound it makes. It isnt THAT loud but it sounds alot more aggresive than stock. I love it and wouldnt trade it for the world. I did have to call borla though, and ask them if they had a 3" for the 04. They are a great company and i HIGLY reccomend them. !Thumbs Up !Thumbs Up
IMO get 3 inch atleast...you dont need anymore then that but 3 is perfect..i hear the borla sounds very nice..and it is a little more affordable then others..
what would be the differences between the 2.5" and the 3"? . . im gonna purchase the BORLA in the spring but want to make sure I get the better one . . . .
Hey Joey, I got that bosal dp installed awhile back and I have the Borla Hush Cat back BUT I kept the after dp cat. The laws are gettin NUTS out here in the west. Folks getting pulled over for even the appearance of a non stock muffler let alone if its quiet or not. Still have the up pipe too. The question here would I really see enough of a difference to risk taking it off now and putting a straight pipe in between the two systems? Track day this weekend for drag, the 29 is an autocross, lots going on soon out here in ABQ. C-ya.
Taking the midpipe out will not yield you very much power. The Cat in there is relatively small, and not all that restrictive. The most restrictive pieces on the stock exhaust are the uppipe cat and the downpipe cat.
Though it is true that bigger pipe diameter is needed to make more power, but only up to a point. The 2.5 inch pipes would be fine unless you plan on making like 300 HP, in which case it would probably make sense to go to the 3 inch pipes. The 2.5 inchers are good beyond what most people will ever use them for.
If bigger pipes automatically meant more power, then why not go 4 inch? Or 6 inch?? For the most part, the other limitations in the system make bigger pipes unnecessary.
Of course, if you get the 3 inchers you have the option of upgrading to the maximum level, but in that case why not just buy an sti?
Just my 2 cents. You can read more about this on Scoobysport NA's site.
I got a Borla Cat-back exhaust back in November. So far I love it, it makes the car sound great and it doesn't look too big or anything. I also took off the silencer around the same time. Which also is great cause you can hear the turbo, in my opinion.
The only bad part is the fact that now I get 30 miles less to my fuel milage . I think it is unavoidable if you make any sort of mods to your wrx.
I have a similar set up to Cosmo & my mpg has dropped from stock bigtime. I get about 200 miles per tank if I baby it. If I run it hard, forget it.
