boost throughout the curve - Subaru WRX Forum
post #1 of 3 Old 12-23-2009, 06:17 PM Thread Starter
After installing my Prosport boost gauge (which I am very please with), I noticed that the boost doesn't drop down, or holds the same PSI throughout the whole curve. Is this true? WRX's don't slowly loose boost like MS3's or SRT-4's? Because my buddy, SRT driver, suggested that I get a better actuator so I can hold boost better through the curve.
Opinons?
ej20_allday is offline
post #2 of 3 Old 12-23-2009, 07:59 PM
It shouldn't hold the entire way.... It SHOULD taper down. Is it tuned ?
What you need is a solenoid (BCS) 3-port preferrably -> (with a tune). Look at prodrive's or GrimmSpeeds
post #3 of 3 Old 12-23-2009, 08:13 PM
VD5505's Avatar
if you get your car tuned it will change where it peaks out, how long it holds at a certain PSI and when it tappers off. What have you all done to that car so far?
VD5505 is offline
