Are you using the stock boost gauge? If you are , what stock level are you talking about? And what gear? 1-2 is different than 3-5? DO you use 91 or 93/94. If you have a aftermarket gauge, what is the true reading?. You said stage 1... or did you mean map 1. Do you have the map selector or not? If it is stage 1, why not run the stage 2 map. Your profile says invidia downpipe and apexi cat back.?? I'm just curious why? A stage 2 should be at 16.5 PSI at around 4-5 k . It can be as high as 17+psi if you have the ABC spun out too much.A stage 2 should be 2 turns out, or around there.
Next is it on WOT , or partial boost?
ANswer some of my ?'s and I can help you out...
jermey
