Old 11-01-2004, 01:04 PM   #1 (permalink)
Reputation: WrxFactor is an unknown
Send a message via AIM to WrxFactor
Boost Problem.. please help!
Ok this is driving me insane. it has happened to both me and my friend. we can not figure this out. ok i put a manual boost controler in my car and he put an electric boost controller. we both recently went to put it back to stock boost control. using the stock solenoid so we can run the stock boost. when we did this we could only get 8psi! we made sure the hoses were on right and we also switched them just to check if that would work and still no luck! please help!
Old 11-01-2004, 01:39 PM   #2 (permalink)
Cosmo's Avatar
Did you make sure you still have the brass restrictor in the hoses? And, if so, did you make sure it's in the right place? It should be between the turbo outlet and the T fitting. I'm willing to bet that's your problem.
Old 11-01-2004, 04:43 PM   #3 (permalink)
i dont have that there but i also dont remember seeing one. how does this brass fitting work? where can i get one if i cannot find mine? thanks for all your help
Old 11-01-2004, 05:58 PM   #4 (permalink)
IBAUCLAPlaya's Avatar
Car: 04 WRX
Trader Rating: (1)
Ditto. Its inside the hose, you can't see it. Its almost like a BB.
Old 11-01-2004, 06:16 PM   #5 (permalink)
Cosmo's Avatar
It would have been in your stock hoses. Squeeze the hose about halfway down it. You should feel it. That hose (with the restrictor) goes between the T and turbo outlet.
Old 11-01-2004, 07:11 PM   #6 (permalink)
not sure if its in there or not but i also have a check engine light code. something to do with my wastegate reading high. do u know what this is about? btw with the mbc i have no boost problems.
Old 11-01-2004, 09:03 PM   #7 (permalink)
Car: 04 WRX
Trader Rating: (1)
What do you mean wastegate reading high? The wastegate doesn't read does it? It is set at a certain pressure to open/close. Check and see if your wastegate is stuck open.
Old 11-02-2004, 08:19 AM   #8 (permalink)
Cosmo's Avatar
That's a common occurance with a MBC. Since there is nothing hooked up to the stock boost control solenoid, it thinks something is wrong.
Old 11-02-2004, 10:45 AM   #9 (permalink)
cosmo please check your pms.
Old 11-02-2004, 11:46 AM   #10 (permalink)
not to all lol. when you modify your boost control make sure to keep ## stock stuff. do not lose it.. lol i just paid 18 bucks for the hose and connectors from the stock bcs to the turbo .. ouch. i hope that is my boost problem
Old 11-04-2004, 09:22 PM   #11 (permalink)
Well i put that brass restrictor in and yeaaah i got boost again...lol but i am getting different boost levels in different gears. 1st and 2nd im getting 10psi a little more in 3rd and 4th and then in 5th it spikes to 15 then down to about 13.5. isnt 14.5 was stock on this car? and shouldnt i be getting that in every gear. I have the hose from the bottom of the bcs going to the turbo is that correct? Will i get better boost levels if i eliminate that plastic connector and just have the hose go from the bcs to the t-fitting? sorry for all the questions lol. any help will be greatly apprectiated.
Old 11-05-2004, 08:46 AM   #12 (permalink)
Cosmo's Avatar
What you're getting is right. It's not uncommon to get less boost in lower gears when the engine is under less load.
