boost problem - Subaru WRX Forum
post #1 of 5 Old 02-16-2008, 12:54 AM Thread Starter
jmoney2648 is an unknown
boost problem
i have an 02 wrx with a tbe, cobb intake, and very recently i removed my mbc in favor of the stock setup, i noticed when i installed the stock hose setup that my car would hesitate around .05 bar for about a half second then contiue to hit target boost. so being an idiot a decided to play with the wastegate arm a little bit so i popped off the c clip and the arm, i rotated the arm clockwise maybe an 8th of a turn, and then moved whatever that piece is on turbo housing in order to reattach the arm, and now my car will spike to 1.5 bar and then drop back down to waste gate pressure in 3rd and 4th gear and spike in 5th gear, so i know its somthing to do with the wastegate. please help!!!!!!!!!!
jmoney2648
View Public Profile
Send a private message to jmoney2648
Send email to jmoney2648
Find More Posts by jmoney2648
Add jmoney2648 to Your Buddy List
jmoney2648 is offline
post #2 of 5 Old 02-16-2008, 02:10 PM
SWFL Scooby's Avatar
SWFL Scooby is an unknown
Turn it back to where it was, make sure the nut and c clip are secure, then reset the ECU by disconnecting the negative battery cable and depressing the brakes.
D-Rock
Under constant pressure
SWFL Scooby is offline
post #3 of 5 Old 02-16-2008, 03:48 PM Thread Starter
my c-clip broke apart when i took it off so there is no clip on there now, would that be a big deal ???
post #4 of 5 Old 02-16-2008, 04:22 PM
Yes, you need the c clip.
D-Rock
post #5 of 5 Old 02-17-2008, 08:56 AM Thread Starter
alright ima go pick up some c-clips 2day and see what happens
