boost gauges and air fuel ratio gauges - Subaru WRX Forum
post #1 of 7 Old 08-21-2008, 11:51 PM Thread Starter
wrxecm's Avatar
Send a message via AIM to wrxecm
i was wondering if anyone knows how to install this gauges or if they have any website that gives exact instructions to how to put them on my 2003 wrx? thanks.
wrxecm is offline
post #2 of 7 Old 08-22-2008, 01:10 AM
it only takes 15-20 minutes to install it. You need a power wire, ground wire, to tap into a existing vacuum line, and a wire that goes to your headlights so if the gauge is equipped with a light it turns on with the other lights. A car shop usually charges about $25-$30 for the install.
this link might help you --> Installing a Boost Gauge
_______________________
Autopartswarehouse addict.
Drive Safely and Move Freely.
Khooper is offline
post #3 of 7 Old 08-22-2008, 07:01 AM
DO NOT get a a/f gauge with the little light that bounces around. If you want to get a a/f gauge, spend the money and get a wideband
_Ryan_
2004 Wrb "BUGEYE"
http://www.misubie.com/
shamrock is offline
post #4 of 7 Old 08-23-2008, 05:49 PM
headstart101's Avatar
Images: 21
yes i would get a wideband its way better and much more accurate.......and easy to install......i use power and ground from my turbo timer.
headstart101 is offline
post #5 of 7 Old 08-24-2008, 04:28 PM Thread Starter
wrxecm's Avatar
whats a wideband? well i already have the auto meter a/f gauge thats why.
oh i didnt know its that fast to put them on. well let me see if i can do this by my own or i gotta take it to a shop.
wrxecm is offline
post #6 of 7 Old 08-24-2008, 09:34 PM
Imprezd02's Avatar
Send a message via AIM to Imprezd02
well, unless the autometer a/f gauge is wideband then its pretty much just flashy lights in your cabin there to look cool. Non-wideband a/f gauges are not accurate at all.
As for the boost gauge, just tap it in to the vac line coming off your bpv on the intercooler.
run it through the firewall and attach to wherever you mounted the gauge. Enjoy monitoring your boost.
Imprezd02 is offline
post #7 of 7 Old 08-25-2008, 10:57 AM Thread Starter
wrxecm's Avatar
alright man thanks and i will enjoy this.
wrxecm is offline
