04-02-2004, 11:16 AM
#1 (permalink )
boost controller reliability
is the single solinoid boost controller more reliable than the dual solinoid ,why?
04-02-2004, 11:23 AM
#2 (permalink )
Both of them are reliable, although neither are recommended for a WRX without other supporting mods.
04-02-2004, 01:15 PM
#3 (permalink )
what are other mods that are required
04-02-2004, 02:01 PM
#4 (permalink )
Depends on how much boost you're running. But an up-pipe without a cat is the first thing you need, if you want to increase boost.
Che
04-02-2004, 02:20 PM
#5 (permalink )
Fuel system upgrades are pretty much a requirement.
04-02-2004, 02:39 PM
#6 (permalink )
Depends on how much you up it by. 1 or 2 psi shouldnt require any fuel upgrades.
Che
04-02-2004, 04:09 PM
#7 (permalink )
Yes, it does. Any increase in boost leads to leaner conditions. The only safe way to do it is to increase fuel too.
04-02-2004, 04:35 PM
#8 (permalink )
IMO that's overkill, then again I am more famaliar with the DSM world. But seeing how Subarus run rich in the first place, only makes sense to me that 1 PSi wouldnt do much harm.
Che
04-02-2004, 05:48 PM
#9 (permalink )
Well, do what you want with your car...
04-02-2004, 08:14 PM
#10 (permalink )
It was my understanding that the WRX came from the factory closer to being lean that rich. That's why a CAI is not a good idea without supporting mods because it leans out the already lean car. I could be wrong so someone with more knowledge on the subject could jump in... Cosmo.
I want a WRX!!!!!!
04-02-2004, 11:43 PM
#11 (permalink )
The CAI thing is due to the angle at which they make the air flow across the MAF. MAF's are sensitive, and little things throw them off.
Linear Mode
