Boost control solenoid - Subaru WRX Forum
 1Likes
  • 1 Post By Jkas
post #1 of 10 Old 04-04-2014, 11:00 AM Thread Starter
Subieblue03's Avatar
Subieblue03 is an unknown
Can you just unplug the solenoid or us it necessary my buddy has a Bugeye that he said his isn't hooked up and runs fine reason for asking is mine stock one is going out
Subieblue03 is offline
post #2 of 10 Old 04-04-2014, 11:34 AM
Jkas's Avatar
Jkas is an unknown
Learning about EBC stuff now. You can run without one. You'll only get wastegate pressure. 10psi. Should throw a code if I remember correctly, going to double check though.
Kasper
2002 WRX Bugeye
2013 Mazda CX-5
Jkas is offline
post #3 of 10 Old 04-04-2014, 11:50 AM Thread Starter
What do you mean only wastegate pressure
post #4 of 10 Old 04-04-2014, 01:36 PM
arcticscythe's Avatar
With the solinoid disconnected your ECU wont be able to control when the wastegate opens. That means the you are relying on the spring inside the waste-gate to regulate the pressure. It limits your maximum boost to the strength of the spring and gives you no control over boost pressure.
For my money I wouldn't just trust the wastegate spring, You can get a solid BCS for around a hundred bucks, if it keeps the engine happy thats worth the money for me.
- Jason
arcticscythe is offline
post #5 of 10 Old 04-04-2014, 01:50 PM Thread Starter
Got I plan on getting a 3 port it's just I was told when you change it you have to tune it
post #6 of 10 Old 04-04-2014, 03:06 PM
boo-key's Avatar
That's correct. Tuning is absolutely required for a 3 port. If you don't want to go that route just pick a stocker up from nasioc. You can find them all day and for cheap.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #7 of 10 Old 04-04-2014, 05:21 PM
I had one til today, just sold it for less than $20. Normal price on a used one shouldn't be more than $40.
Good luck
post #8 of 10 Old 04-05-2014, 06:09 AM
Fidrat's Avatar
So,when I go to my tuner I can install my new Grimmspeed BCS in the parking lot (they charge $50) and just don't plug it in to drive it into the bay? I'm told don't drive it one inch with it hooked up without a tune. Is this true?
Fidrat is offline
post #9 of 10 Old 04-05-2014, 06:58 AM
You won't hit hardly an oz of boost pulling in the door. I'm calling bullshit on that one.
post #10 of 10 Old 04-05-2014, 02:27 PM
Jkas's Avatar
Jkas is an unknown
If you do, thats a hell of a launch into the garage.
Epictofer likes this.
Kasper
2002 WRX Bugeye
2013 Mazda CX-5
Jkas is offline
