-   -   Boost control solenoid (http://www.wrxtuners.com/forums/f52/boost-control-solenoid-46873/)
Subieblue03 04-04-2014 12:00 PM
Can you just unplug the solenoid or us it necessary my buddy has a Bugeye that he said his isn't hooked up and runs fine reason for asking is mine stock one is going out
Jkas 04-04-2014 12:34 PM
Learning about EBC stuff now. You can run without one. You'll only get wastegate pressure. 10psi. Should throw a code if I remember correctly, going to double check though.
Subieblue03 04-04-2014 12:50 PM
What do you mean only wastegate pressure
arcticscythe 04-04-2014 02:36 PM
With the solinoid disconnected your ECU wont be able to control when the wastegate opens. That means the you are relying on the spring inside the waste-gate to regulate the pressure. It limits your maximum boost to the strength of the spring and gives you no control over boost pressure.
For my money I wouldn't just trust the wastegate spring, You can get a solid BCS for around a hundred bucks, if it keeps the engine happy thats worth the money for me.
Subieblue03 04-04-2014 02:50 PM
Got I plan on getting a 3 port it's just I was told when you change it you have to tune it
boo-key 04-04-2014 04:06 PM
549 Attachment(s)
That's correct. Tuning is absolutely required for a 3 port. If you don't want to go that route just pick a stocker up from nasioc. You can find them all day and for cheap.
BLAZE2099 04-04-2014 06:21 PM
I had one til today, just sold it for less than $20. Normal price on a used one shouldn't be more than $40.
Good luck
Fidrat 04-05-2014 07:09 AM
So,when I go to my tuner I can install my new Grimmspeed BCS in the parking lot (they charge $50) and just don't plug it in to drive it into the bay? I'm told don't drive it one inch with it hooked up without a tune. Is this true?
BLAZE2099 04-05-2014 07:58 AM
You won't hit hardly an oz of boost pulling in the door. I'm calling bullshit on that one.
Jkas 04-05-2014 03:27 PM
If you do, thats a hell of a launch into the garage.
