blow through set up - Subaru WRX Forum
post #1 of 11 Old 09-13-2006, 09:13 AM Thread Starter
Send a message via AIM to Black Night
blow through set up
im interested in running a blow through set up, however im not sure where to place the mas sensor, any advice?
Black Night is offline
post #2 of 11 Old 09-13-2006, 11:18 AM
Relocate your MAF after the BOV.
ScoobyWRX is offline
post #3 of 11 Old 09-13-2006, 11:59 AM
Do you plan on duing it with a TMIC or FMIC.It would be alot easier to do with a FMIC.They are alway selling the MAF flanges on Ebay.
dumdum is offline
post #4 of 11 Old 09-15-2006, 03:43 PM Thread Starter
im doing it on a TMI...im going to keep that set up...but where exactly after the blow off valve, im also running an hks SSQV if that makes a difference
post #5 of 11 Old 09-15-2006, 05:13 PM
Then it would have to go between the intercooler and the throttlebody.Are you doing this yourself?
dumdum is offline
post #6 of 11 Old 09-16-2006, 08:46 AM Thread Starter
yeah i do all the work to my car myself, already done clutch, flywheel, downpipe, up-pipe, boost controller which has been taken off, intake, things like that...thanks for all the help guys
post #7 of 11 Old 09-16-2006, 05:14 PM
FYI: you will need to have the MAF perfectly centered and in a 65mm inner diameter pipe.Custom tune is highly recommended as well as some professional help.Not sure if the MAF and IAT sensor will handle being under boost.No offense,but if you couldn't figure out where the MAF was suposed to go,this might not be the project for you.It's alittle more involved than just moving the MAF sensor.
dumdum is offline
post #8 of 11 Old 09-17-2006, 04:27 PM Thread Starter
haha no offense taken...obviously the tune i cant do myself, but as far as the actual work i know im capable of, but thankyou for the heads up
P.S.....the reason i asked where it went is because ive heard three different locations so i was kinda confused, not that i had no clue whatsoever
post #9 of 11 Old 09-18-2006, 08:46 AM
I really haven't seen anyone do it with a top mount because the space is so limited between the intercooler and the throttlebody.You can barley fit a coupling in there.If you remove the coupling and re install the tmic and measure the distance between the tb and tmic openings you will see they are close to touching inside the coupling.Much easier to use a FMIC because you have a lot of piping to work with from the FMIC outlet to the throttlebody.Much better options for mounting.Are you just doing this to run an atmospheric bov?
dumdum is offline
post #10 of 11 Old 09-18-2006, 12:28 PM Thread Starter
well, yes and no....ive also read that its better to relocate it to run a cai....that way it doesnt lean anything out
post #11 of 11 Old 09-18-2006, 04:21 PM
Nope.The lean issue is caused by the intake diameter not being same as stock,MAF not being properly aligned in the aftermaket intake,MAF mounted to close to a bend(turbulence) or to much oil on an oiled filter.Doesn't do any other benifit but to allow you to run an atmospheric bov with out issues.
dumdum is offline
