getting the walbro fuel pump. for my setup and the boost im going with my tuner said I didnt need the injectors just yet.
The stock injectors are tiny. You can max them out with the stock turbo. I'd wager without injector upgrades and a turbo that big you'll make less torque than a stage 2 wrx would. It's really a required upgrade to use that turbo effectively. You'll also need a TMIC or else you'll limit horribly on the top end as well.
Yes, throwing a big turbo on without enough fuel and without enough cooling can actually reduce your performance.
16G powered lagless fun
The wastegate on the stock turbo went so instead of just getting the wastegate then doing a turbo later anyway I decided just to do the turbo. Ill now be looking into some injectors and the STi intercooler.
Chucks stage 2 WRX tuned by Ray @ TurboTekTuning.com
16G it's so pretty
## gonna be runnin low psi with the stockers. if ## not gonna beat or race i guess u could do them but that juat defies the point of gettin a bigger turbo loll. im runnin b16g myslf but stock tmic. i dont feel much lag at high rpm since im at 13 psi but i dont spool till like 3000rpm. if u on a budget, grab an ebay tmic. ther huge but u need to extension for the y pipe. im sellin an ebay tmic 24x12x4.5 and i extended the y pipe to fit. let me no if ## interested. its basically brand new. 100miles on it
If you have stock injectors and stock TMIC, the best thing you can do is leave the stock turbo in there. "Upgrading" is counter-productive. Leave the 16G on the shelf until you can afford some more parts.
Should have the STi intercooler soon and going to get the injectors too. Also getting rid of my bov and going with the perrin recirc since when I bought my car used it had a bov on it and I dont have a stock one to put back on
16G it's so pretty
