Originally Posted by 02subiecolin
I would like to do drag racing the only thing that I was trying to do is try and squeeze out as much power that I can out of the 2.0l everyone has been telling me that I should stroke it but If I am going to stroke it wouldn't it make more sense to buy the 2.5l motor
If you were going to do more than drag race (Rally/AutoX) a 2.3l would be great..those are TQ monsters.
To get the
most out of your EJ20 you will need to build the heads as well as the block to safely support a 30r turbo. If lag isn't a big deal go ahead and get a 35r sized turbo if you are going to build the rest of the motor
If I was to build an EJ20 Mod List (budget not in mind):
Standalone ECU
P&P Heads - with Valve upgrade, Springs, and retainers (stronger head studs)
Billet Crank with stronger bearings, rods, and pistons
Higher Flow Intake Manifold
a True 3" or 3.5" exhaust
Equal Length Headers
Wide Band O2
Solid Motor/Tranny Mounts
12mm oil pump
STI Oil Pan
Bigger front brake calibers at least
at least 850cc injectors/255lph pump to tune with E85
This is just for the motor - If you are going to drag race with a lot of power you will need to consider spending at least 5k on your tranny.
