Just got Autometer oil temp gauge. They recommend install of sender boss into the oil pan (drill hole and weld in the boss ring that the sensor threads into)...
anyone know of a better location? possibly the oil filter adapter, or does the WRX have an external oil cooler (maybe tap into the outgoing line)?
To tap the oil pan, it must be removed so that drilled particles don't enter the inside of the pan... that's a pain in the rear. (new gasket, messy job, need perfect torque of oil pan nuts, need perfect location so that crank and rod assembly aren't in the way)...
Who's runnin oil temp gauges and how'd you install? I need help please.
oil pan is rtv'd factory.......not too bad to do. 1/4" drive swivel sockets are your friend. best place to put it is in the oil pan, down lower. crank doesnt stick down too far, but look while its apart. hope this helps.....good luck
use permatex ultra grey, best rtv ive found for oil contact. as good as subaru(or nissan, if you got it...had some left over from a timing chain cover job on a ka24 in a altima) ultra grey is REAL good stuff, just clean every surface off good with parts cleaner.
sealant instead of a cut gasket. autozone should have it...i get mine at napa. when you pull the bolts out, the pan will still be "glued " into place. you will need to insert a chisel-like object, ie screwdriver, between pan and block, and pry it away. then make sure the flange is straight when its off the car. razor blades are needed to remove most of the old sealant. clean well, then use carb cleaner or the like to remove oil from the flange and block. lay a 1/4" bead all the way around the pan flange, makin sure to go around the bolt holes. place the pan when youre done, and torque it into place. let it sit for a few hours, pref. overnight, to let the sealant set up, then fill with oil, and run. enjoy. good luck
Thanks FC... I figured it out last night.. Found some Permatex at Walmart and once i read the label and saw what it was... i figured it was used only as gasket, and no actual gasket had to be purchased
