-   -   Best Guages for a 2- or 3-Guage A-Pillar Cluster (http://www.wrxtuners.com/forums/f52/best-guages-2-3-guage-pillar-cluster-34345/)
LW_Black4 04-21-2013 08:39 PM
2 Attachment(s)
This may sound like a novice question, but [B]what are the best guages to put in a 2- or 3-guage A-pillar cluster on an '04 WRX?[/B]
This is one example:
1. Boost [psi],
2. Oil temp, and
3. Oil pressure.
And is installation a straight forward DIY exercise, or am I going to need a performance shop to do it?
brfatal 04-21-2013 10:04 PM
Not a fan of a-pillar. They reflect off the window.
the RIOT act 04-22-2013 12:34 AM
I'd go with boost, egt, and oil pressure first myself.
The reasoning for boost and oil pressure are pretty obvious, although both are a must know. And the egt will give you a general indication of air/fuel and your knock/detonation thresholds. It'll also give you fair warning when you're pushing to hard.
boo-key 04-22-2013 04:56 AM
549 Attachment(s)
boost, air/fuel ratio, and exhaust gas temp. Just my opinion. No performance shop needed if you have ever wired anything in a car before. Power , ground, and sensor which usually has a pre-wired connector. simple as that!
man show 04-22-2013 10:31 AM
2 Attachment(s)
I have three Prosport peak/warn gauges (boost, exhaust gas temperature, and oil pressure) mounted in a Lotek triple A-pillar pod which came painted light grey to match the stock trim. Fitment is pretty good - I'd give it a 9/10 because you can see some marks around the top edge where it was trimmed, but it's only really noticeable if you look directly at it. There's also a tiny little gap where the headliner isn't completely covered where it was by the stock A-pillar cover, but that's getting really nitpicky. The surface texture matches the stock trim pretty well. I actually only have it held in by one screw at the top (which I had to drill into the A-pillar) - the bottom screw is just for show (because there wasn't enough clearance for the drill), but it's solid because there's a plastic tab that holds the bottom in place. The green backlighting, although it matches fairly close, is brighter than the gauge cluster at night and I've been told people driving behind me can see them through my black glass (which is tinted 35%). You can also see them clearly through the driver's window if you're driving next to my car at night (also tinted 35%). From a driver's perspective though, glare/reflection on the driver's window is not an issue. Having both oil pressure and oil temperature gauges would be redundant. There are plenty of good write-ups available online, so it's definitely a DIY job if you take your time and pay attention to the details. Fuse taps made my install super easy and they're completely reversible.
LW_Black4 04-22-2013 01:38 PM
1 Attachment(s)
[B]Thanks folks, this is great input.[/B]
I agree oil pressure and temperature are a little redundant, so if I can't find an surplus OEM unit I'd consider a twin guage cluster for boost and oil temp like this SMY Clustermaker Dual Guage Pod:
the RIOT act 04-22-2013 02:11 PM
I plan on buying that cluster setup from them as well. It's very clean an OE looking which I love!
Big easy 04-22-2013 10:33 PM
Why do you guys all like the exhaust gas temp gage over a wideband air fuel ratio gage.
Big easy 04-22-2013 10:38 PM
Oh and [B]GLOWSHIFT[/B] has some nice gauges and usually some pretty good deals.
brfatal 04-22-2013 11:57 PM
[quote=Big easy;298377]Oh and [B]GLOWSHIFT[/B] has some nice gauges and usually some pretty good deals.[/quote]
*rubs eyes* Did....you really say that? Please don't ever post advice again.
Glowshift is garbage.
man show 04-23-2013 09:32 AM
Admittedly, Prosport gauges are considered to be borderline garbage too. I got mine for general monitoring, but mostly for show. If I was actually using my gauges to tune my car and keep an extremely close eye on everything all the time, I would have gone with Defi gauges and a wideband AFR gauge. Generally, the more you pay, the more accurate the gauge will be. For my purposes, I'm willing to live with a 10% (+/-) variance. After several years, the needles still move and they seem to be somewhat accurate so I'm a satisfied customer.
LW_Black4 04-23-2013 12:44 PM
[quote=man show;298465]Admittedly, Prosport gauges are considered to be borderline garbage too. I got mine for general monitoring, but mostly for show. If I was actually using my gauges to tune my car and keep an extremely close eye on everything all the time, I would have gone with Defi gauges and a wideband AFR gauge. Generally, the more you pay, the more accurate the gauge will be. For my purposes, I'm willing to live with a 10% (+/-) variance. After several years, the needles still move and they seem to be somewhat accurate so I'm a satisfied customer.[/quote]
Well said.
brfatal 04-24-2013 08:13 AM
A gauge not providing accurate readings is a gauge not doing its job. :shhh:
man show 04-24-2013 09:22 AM
[quote=brfatal;299042]A gauge not providing accurate readings is a gauge not doing its job. :shhh:[/quote]
But it's still lighty and flashy and movey and pretty!!! <3 :p
the RIOT act 04-24-2013 09:29 AM
^^LOL^^
