BCS Help - Subaru WRX Forum
post #1 of 3 Old 03-17-2009, 08:45 PM Thread Starter
Nic17fly's Avatar
Send a message via AIM to Nic17fly
BCS Help
Hey everyone, I just installed a perrin Electronic Boost Control Solenoid on my 02 WRX. I set it up the same way the factory one was set up so it is a slow bleed, I only did this because the stock one wasn't working properly. Anyway, when I took it for a test drive the new BCS is making a very audible annoying tapping sound when I touch the throttle. To describe the noise it sounds like a wood pecker is under my hood. This can't be normal can it?
Nicolas
BUGEYES FOR LIFE
Nic17fly is offline
post #2 of 3 Old 03-17-2009, 10:21 PM
Is it a 3 port? If so it has to be tuned directly after installation.
post #3 of 3 Old 03-18-2009, 12:14 AM
c2bcoolwrx's Avatar
+1 you need a tune. However, a light tapping or buzzing sound is normal from a 3 port BCS. As long as the sound is comming from the BCS your fine as long as you get a tune.
c2bcoolwrx is offline
