» Sponsor Links
»Garage Storage and Cabinets
Old 05-18-2004, 09:02 PM   #1 (permalink)
Reputation: SiDsWRX is an unknown
Send a message via AIM to SiDsWRX
Talking APEXi Turbo Timer
I have a Apexi TT and i was wonder if the A/F gauge on the Timer will work for the WRX, or would I have to buy a different one? Any suggestions? Thanks
Old 05-18-2004, 10:22 PM   #2 (permalink)
IBAUCLAPlaya's Avatar
Car: 04 WRX
Trader Rating: (1)
No it won't you need a wideband O2 sensor. Check out TurboXS.com
Old 05-19-2004, 08:33 AM   #3 (permalink)
WRX_2NR's Avatar
Car: 04 WRX
Reputation: WRX_2NR is an unknown
I would not use the A/F on the TT
Its not accurate
If you want a good tuning unit get a Wideband O2 setup
Old 05-19-2004, 08:35 AM   #4 (permalink)
Cosmo's Avatar
I think he's talking about the way the Apexi TT reads the O2 sensor to determine how long for the car to idle. But either way, it won't work...
Old 05-19-2004, 08:43 AM   #5 (permalink)
WRX_2NR's Avatar
Car: 04 WRX
Well I have the Apexi TT
It takes little bit of driving to get the sensor to warm up and read close, but its still not a good tool to use for tuning, but after about 10min the A/F reading should be close
You can also scale the O2 sensor value to give you a more accurate A/F, but I just use the reading for auto mode only
