Any Issue Rebuilding With an '04 STi Crank & Rods in an '04 WRX? - Page 2 - Subaru WRX Forum
 9Likes
post #16 of 18 Old 02-24-2014, 03:37 PM
You're better off with a stock rebuild/replace. Much easier to explain when you inevitably sell the car too.
LW_Black4 likes this.
post #17 of 18 Old 03-07-2014, 11:45 AM Thread Starter
LW_Black4's Avatar
In a stroke of good fortune I was given a spare EJ205 shortblock in good condition which had 140,000 km on it. It's condition was verified by a reputable builder, so it seems like a good place to start.
With a spare EJ205 shortblock I can get started early on my rebuild. If I can find rebuilt heads where I'll get credit for the old cores, I might be able to have a longblock built before I pull the old engine out, making an engine swap potentially a weekend operation.
This would be great!
Laszlo - white '11 STi sedan
LW_Black4 is offline
post #18 of 18 Old 03-13-2014, 03:25 PM Thread Starter
LW_Black4's Avatar
Looks like this build work is going to be coordinated by Touge Tuning, likely in the fall.
1. Rebuild the spare EJ205 shortblock in advance
- Gates OEM Water Pump & Timing Belt Kit - 2004-2005 Subaru WRX
- 4032 alloy forged pistons
- OEM or equivalent bearings
- OEM head gasket
- 10 mm OEM oil pump
- ARP head studs
2. When shortblock ready, yank the engine and deliver the heads.
3. Cylinder head service (1 – 2 day turnaround)
- Basic head service that is done is cleaning, pressure testing and decking the heads, plus re-shim valves/cams, valve seats redone, parts replaced as required
4. Pick up longblock when heads ready and assembled
- Likely in a GTI with the rear seats folded forward to make a deck
5. Reassemble the engine on an engine stand in Orillia and then re-install in the WRX.
Always good to have a plan ready just in case of an unexpected failure, and a fall build timeline allows an interim Stage 1 tune to participate in this year's performance motoring season. This is good!
