So, once again, through all your guy's help and information i have revised another mod list....... :tease: So i just decided to run it by you guys AGAIN to see what you guys think. !Thumbs Up I'm hoping to actually GET my WRX by end of June, early July, and then i'm hoping to be at least Stage 2 by August WTF, ### we gots a H.I.N here in Cali in mid-ish August... Even if i'm not Stage 2 by then, i'll be fine with just a Stage1...
So, i plan on buying the Rex in late june, early July, and then first thing is a K&N drop-in filter. And then ima get the COBB AP and flash to Stage1... Then i gota start researching and looking around for Invidia UP and DPs. But basically i'm hoping to be Stage2 by at least the next year, to give me some time to get used to the car...
Ok, so now i've revised my mod list like 3 or four times, and each time taking things off and adding others after learning this and that. So now i beleive i know enough about the WRX to make a final mod list. I'm only shooting for close to 300whp, nothing huge, just want a nice power gain anytime i need it.
Power Adders (mostly in order of future purchase)
K&N drop-in filter
Royal Purple (Motor oil, Max Gear, Purple ICE)
COBB AccesPort
Invidia UpPipe and Downpipes
HKS Hi-Power Cat-back-Exhaust
660cc injectors
Walbro 255lph Fuel Pump
Either upgrade TMIC, or an SSaC FMIC kit painted black :shhh:
And then to bring up the rear on the power-adder side, an EVOIII Big 16G turbo upgrade
Boost, EGT and AFR gauges, plus wideband o2 sensor
Suspension/Drivetrain
TEIN lowering springs
Kartboy endlinks
Whiteline SwayBars
COBB ShortShifter
ACT Stage 1 or 2 clutch
MAYBE A lightweight pulley set
Ect.
HKS Shift Knob
Rear Air Diffuser
Seibon Front Lip
PS: Most of the Suspension/Drivtrain, Ect. stuff will be bought AFTER i get the more important stuff.
