Air Silencer Removal On Sti? - Subaru WRX Forum
post #1 of 5 Old 05-08-2005, 07:38 AM Thread Starter
janes5150 is an unknown
can you do this to a sti?if so is it the same proccess as with wrx?
janes5150 is offline
post #2 of 5 Old 05-08-2005, 11:57 AM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Yes it should be the same
Ian is offline
post #3 of 5 Old 05-08-2005, 04:54 PM
IBAUCLAPlaya's Avatar
Same process, just did it to an 05 STi.
IBAUCLAPlaya is offline
post #4 of 5 Old 05-08-2005, 10:19 PM Thread Starter
i have searched and not found any links about how to do this.soem help would be great.im guessing it is as simple as removing the fender liner and taking it off.but a wtite up would be nice
post #5 of 5 Old 05-09-2005, 12:23 PM
Yup it is that simple. Remove the ram air scoop, remove the nut on the inside of the engine bay holding the snorkus in, then lift the front passanger wheel and pull the fender liner (removing the wheel as well makes it easier) and then reach around the snorkus and you will feel another 10 mm nut to remove. Then just pull it out.
