Air Intake Questions - Page 3 - Subaru WRX Forum
post #31 of 34 Old 03-29-2012, 05:42 PM
cjohns2002's Avatar
i checked the fuel pump and it is around 37-39 psi, low for the vehicle. I thought the cobb wouldnt need a tune but apparently im wrong. But back to the fuel pump from what i found it should be between 41-46psi. I put the stock air box back on after work today and im gonna see from there if the light comes back on. I do plan on upgrading the fuel pump to the walboro 255 and also putting injectors in, but i want it to run correcly first lol
cjohns2002 is offline
post #32 of 34 Old 03-30-2012, 05:57 AM
50psi max from my research on the stock pump. That may be the issue. Also could be the filter.
The OTS maps are "ok" but I personally wouldn't run it for a LONG time. Some have had no problems.
post #33 of 34 Old 03-30-2012, 05:58 AM
Originally Posted by spc2125 View Post
Just a quick question. What kind of intake can you install without needing a tune (just for sound)?
Without any engine management?
post #34 of 34 Old 03-31-2012, 12:19 PM
cjohns2002's Avatar
I installed the stock air box and im trying it and so far the light has stayed off. And also have a walbro 255 hp FP on the way. Thanks for the support. O and I replaced the filter 2 weeks ago when I did the plugs.
