Air Intake Questions - Page 2 - Subaru WRX Forum
post #16 of 34 Old 03-25-2012, 05:11 PM
cjohns2002's Avatar
cjohns2002 is an unknown
Hey guys just another question. I installed a cobbtuning short ram on my 02. I also have the cobbtuning stage 2 tune in it but it threw a cel for bank 1 lean. Any info help?
cjohns2002 is offline
post #17 of 34 Old 03-25-2012, 09:21 PM
Do you have the Cobb SF Stage 2 Map on your car or the stock air box stage 2 map?
AccessPORT Off The Shelf Maps
post #18 of 34 Old 03-25-2012, 10:21 PM
bad grocerygetter's Avatar
The maps for the 02s are the same with the Sf or the stock airbox. Not sure what would be causing that cel. Dirty maf???
Kevin.
bad grocerygetter is offline
post #19 of 34 Old 03-26-2012, 06:17 AM
Leak of some sort. Check the coupler to the TMIC.
post #20 of 34 Old 03-26-2012, 08:08 PM
cjohns2002's Avatar
I just found the stage 2 map with the sf option. I will check for the leaks but hopefully the new verion of the map will help. The stage 2 93 v3.10 I cleaned the MAF at work and it still was on so cross my fingers.
post #21 of 34 Old 03-26-2012, 08:30 PM
3.10 made a huge difference on my car. Not anything power wise but how it actually runs. It was smelling pig rich before hesitating on acceleration, after the update all that is gone. And my gas mileage seems to be slightly better.
Kevin.
post #22 of 34 Old 03-28-2012, 05:16 PM
cjohns2002's Avatar
Well the cel came back. Bank 1 too lean after the install of the 3.10. It seems to run good but the cel buggs the crap out of me. I need suggestions. The things I did right before the cel came on. New spark plugs and the cobb sf. Also put the factory bov back on after 2 days having the turboxs hybrid.
post #23 of 34 Old 03-29-2012, 05:49 AM
Did you reset the ECU or just a reflash after clearing the CEL?
How'd the plug install go?
post #24 of 34 Old 03-29-2012, 07:58 AM
cjohns2002's Avatar
I cleared the cel then installed the tune. Nd the plugs were not actually as bad as most people made them seem done in under a hour and a half
post #25 of 34 Old 03-29-2012, 08:43 AM
They aren't bad, with the right tools.
And you flashed after the latest firmware update?
post #26 of 34 Old 03-29-2012, 11:41 AM
cjohns2002's Avatar
Yea I had to download the map to the accessport and I updated it when it was connected. And no intake or exhaust leaks found. I just checked today
post #27 of 34 Old 03-29-2012, 01:35 PM
Damaged MAF or it just needs a custom tune.
Edit: you know, this has been happening more and more lately... Maybe its just me.
Could be a faulty FP. Have any datalogs ?
post #28 of 34 Old 03-29-2012, 01:57 PM
cjohns2002's Avatar
Im new to the modding world no data logs. I don't know what to look for or record. And also what's FP?
post #29 of 34 Old 03-29-2012, 02:11 PM
Fuel pump.
You have a way to chk the pump pressure? Read up on datalogging on Cobb's website... Or here even.
post #30 of 34 Old 03-29-2012, 03:53 PM
spc2125 is an unknown
Just a quick question. What kind of intake can you install without needing a tune (just for sound)?
spc2125 is offline
